Author Topic: Plunger Removal Topre  (Read 2299 times)
Offline IPT
  • Formerly projectD
« on: Mon, 23 December 2013, 10:42:58 »
So im trying to figure out the best way to remove the plunger on my topre board to give it a full cleaning.
I can't figure out how to remove the plunger piece as it seems to have a lock/snap in backing
anyone ever remove the plungers for cleaning b4??
Offline RabRhee
Re: Plunger Removal Topre
« Reply #1 on: Mon, 23 December 2013, 13:45:53 »
Although there is that little notch on the stem to stop it disappearing down the switch, I found that with the little bit of play in the stem, I could move it so the notch had all the available gap, and then just tap the stem down with a phillips screwdriver inside it, very gently and it just popped out. I think the only worrying part would be if you rounded the notch's bottom edge off, and I think that would take repeated removals, or hitting it too hard to remove.
That was just my own limited experience of it, but many are removed to silence and replace. I was concerned about it but found it was no stress.
-Life is good-          Crafting: |  Keychains |  More.   .Keychains | Crowdsource Key | Budget Keycap Board |
« Reply #2 on: Mon, 23 December 2013, 13:52:38 »
I removed them when I added Dental Bands, I flip the board over and with the backend of my tiny screwdriver (ps3 controller screwdriver) it is the same size as the plunger, i push it against the plunger and it pops out.
« Reply #3 on: Mon, 23 December 2013, 14:43:48 »
I just used a spudger and firmly pushed until they popped out.
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #4 on: Mon, 23 December 2013, 15:41:11 »
I was pointed out to this link awhile ago by 002 when it came to removing the plungers. It was a thread on deskthority:
http://deskthority.net/workshop-f7/hhkp-pro-jp-variable-force-silencing-mods-t5196.html#p100197
Have a look at what 002 asked and then the response from OP (dpanth3r).
HHKB Pro JP Type-S | Northgate Omnikey 101 | APC/"Clicker" F-21 (GOG3YL) | Cherry G80-5000 HAMDE
僕の日本語が下手です。我的中文也一樣爛。
