Author Topic: Who knows a lot about cherry switches?  (Read 2555 times)
Offline billm
« on: Mon, 02 February 2009, 13:48:24 »
I just came across some in a local shop. The part number is MX1AC1NW and they have white plungers. They're tactile but not clicky. I thought these were supposed to be brown or "tea" colored? If so why are these white?
Does anybody know the cherry part number for the brown ones?
If it's not ALPS it's crap!
Offline dw_junon
    • http://www.9999hp.net/
« Reply #1 on: Mon, 02 February 2009, 13:58:10 »
Wouldn't say I know much, but anyway.
The MX1AC... switches are the indeed the white or "clear" stem ones, those are the ones that are tactile (like the blues) but have no click (not like the blues). The brown you are looking for is "G".
Nice find, by the way.
ARC/Chicony KB-5181 XT/AT blue ALPS? 101 US FCC ID E8H51KKB-5181 • AST ASTKB102 AT capacitive rubber dome 102 UK ISO
Cherry G80-2100 AT black Cherry 126 key German ISO unique • Compaq Enhanced III PS/2 unknown rubber dome 102 UK ISO
Datacomp DFK102ARA03 AT 102 blue ALPS? US/Arabic FCC ID blank, S/N 37880001 • Dell AT102W PS/2 Black ALPS 105 UK ISO x2
Fujitsu KFB4725-102 AT membrane rubber dome with spring 105 UK ISO • Hewlett Packard C1405A AT rubber dome 102 UK ISO
IBM 0989705 XT/AT no LEDs Model M 102 US/Arabic  • IBM 1388076 Industrial AT Model M 102 UK ISO
IBM 1389260 3179/3180 Display Station Model M 122 US 3270 x2 • IBM 1391406 PS/2 Model M 102 UK ISO x2
IBM 1397003 PS/2 Model M "Host Connect" emulator 122 German ISO • IBM 71G4643 PS/2 Model M Quiet Touch "Ouch!    Rubber spring" 102 UK ISO x2
IBM 5640987 3178 Display Station Model C2 capacitive buckling spring 87 key US 3270 • IBM 556-712-01 RT PC rubber dome [same as 2nd PCjr kbd?] 101 US
IBM 6450225 PC/AT capacitive buckling spring 84 key UK PC/AT • Lexmark 8125460 Model M2 102 UK ISO
NMB RT-102 117456-002 AT Hi-Tek black, clicky 102 UK ISO • Olivetti ANK 2462 M24 Personal Computer keyboard 2 clicky Olivetti spring module 102 UK unique
Ortek MCK-142Pro AT white ALPS 142 key UK • Sun 540-1006-03 Type unknown linear(?) keyswitch 2 87 key SunType2
Wang 724 725-3771-UK salmon ALPS 110 key UK Wang724 • Making this list hasn\'t half scared me...
[/I]
Offline bhtooefr
    • bhtooefr.org
« Reply #2 on: Mon, 02 February 2009, 14:02:27 »
Clear stem is normal weight, soft tactile. Brown stem is "ergonomic" soft tactile. IIRC, clears are 60 g, browns are 55 g.
Offline billm
« Reply #3 on: Mon, 02 February 2009, 14:59:44 »
Quote from: bhtooefr;20614
Do you know what the force on the blacks are, by way of comparison? These feel stiffer than the blacks.
Offline Chloe
  • Switch Kitten
« Reply #4 on: Mon, 02 February 2009, 15:33:56 »
Operating force of black/linear is 60cN. Tactile force of clear stem is 65cN which might explain why they feel stiffer. Operating force of clear stem is 55cN, browns are 45cN.
