Author Topic: Razer Blade LED swap  (Read 6656 times)
Offline Pynk
« on: Tue, 24 December 2013, 13:41:09 »
Hi All,
Just got myself a razerblade but really don't like the green LED, was wondering if anybody has seen or know how I might be able to change the LED on it?
Thanks
Offline OldDataHands
Re: Razer Blade LED swap
« Reply #1 on: Tue, 24 December 2013, 14:02:47 »
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« Reply #2 on: Tue, 24 December 2013, 14:03:33 »
« Reply #3 on: Tue, 24 December 2013, 14:12:18 »
The Razer Blade is a laptop
Ok. still, the discussion about LED
brightness, voltage drops, current control
resistors may be useful.
Offline fourzeropooh
« Reply #4 on: Tue, 24 December 2013, 15:08:04 »
May I ask why you decided to go with the razer blade?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Tue, 24 December 2013, 16:02:57 »
I'm fairly certain it will be all surface mount LED since it's a thin chiclet keyboard. Unless you have a lot of experience with surface mount and the correct equipment it will be a very hard task.
Offline Pynk
« Reply #6 on: Wed, 25 December 2013, 10:21:01 »
Initially wanted to get the Alienware 14, but after seeing the actual thing it really didn't look sleek even though it had color changing LEDs....
I live in Singapore
Alienware 14 in SG is $2,159 USD
exact same model sold in the US $1,299USD
Blade 14 in SG is $2,639 USD - but I got it for $1,976USD
exact same model sold in the $2,299 USD
So Blade was just cheaper and I wouldn't feel as badly ripped off.. if I could get the alienware at $1299 would probably have did that instead.
Offline jadow
« Reply #7 on: Wed, 25 December 2013, 12:24:18 »
I live in Singapore
anything you do will void the warranty. Easiest way is to tape over it.
