Author Topic: Anyone Steel Series 6gv2?  (Read 1981 times)
Offline frowni
  • i love typing!
« on: Fri, 27 December 2013, 08:25:50 »
Hey there,
I'm using Filco's for last 3 years..i own Browns..and got 2 other Blues(MJ1 and 2) but don't use the blues anymore. It's hard for me to find or order these keyboards anymore(my countries customs is ****)
I really want to try a linear switch and all i can find is Steel Series 6gv2 with mx blacks(we don't have reds edition)
So, how is the quality? I know its much cheaper than filcos :) Oh and by the way, i use filco tenkeyless...I'm used to use Tenkeyless since its better that your mouse is much closer to your hand...
Should i buy it? I can't even try it in the shop...
Offline Tym
Re: Anyone Steel Series 6gv2?
« Reply #1 on: Fri, 27 December 2013, 08:29:32 »
Good quality board, built solid.
Only problem is the odd layout with the bigass Enter Key and the tiny right shift. Nothing wrong with them, but you're going to have a bad time if you want to replace the keys.
Offline whiteduck
« Reply #2 on: Fri, 27 December 2013, 08:31:29 »
ss 6gv2 was my first board and I don't regret buying it - it was a great board to game with.  I wouldn't call it "much cheaper than filcos".  Only issue you would have with it is trying to find replacement keycaps if that is important to you.
daym tym ninjas
-wd
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
« Reply #3 on: Fri, 27 December 2013, 08:34:16 »
Tis a good quality board for the money, its heavy, good solid plate etc, but as mentioned, odd layout and weird enter key.
Offline Tym
« Reply #4 on: Fri, 27 December 2013, 08:41:08 »
daym tym ninjas
Offline dante
« Reply #5 on: Fri, 27 December 2013, 08:53:19 »
For gaming it's ok - but mine had HORRIBLE keycap printing - the worst of any board I've ever owned.
Offline BlackWidowMan777
« Reply #6 on: Fri, 27 December 2013, 20:05:02 »
You can get around the displaced short right shift by using 'sticky keys' when typing. The keyboard feels like it was forged out of cast iron. I would highly recommend this keyboard if you are looking for a no-frills tank that gets the job done well. I prefer it over the ducky zero w/ blacks for its more solid feel and reassuring clack when bottoming out.
Edit: no wonder - they used a special iron-infused plastic case according to the SS website!
« Last Edit: Fri, 27 December 2013, 20:41:55 by BlackWidowMan777 »
Offline terran5992
  • One With The Cup Rubber
« Reply #7 on: Fri, 27 December 2013, 20:05:44 »
Small backspace and non standard keycaps
Stay away from it
Offline Tym
« Reply #8 on: Fri, 27 December 2013, 20:16:13 »
Stay away from it
That is the 7g not the 6gv2, which has a standard backspace.
