Author Topic: Keyboard filler  (Read 2989 times)
Offline keymaster
  • Topre Revolution Theorist
Keyboard filler
« on: Fri, 27 December 2013, 14:02:21 »
I'm trying to purchase something like this filler for controlling ressonance from a vendor in the U.S.
I've found this one on Amazon. I just want to make sure -- will it be fine to use it as keyboard filler (underneath the PCB)?
« Last Edit: Fri, 27 December 2013, 14:55:27 by keymaster »
Offline Photoelectric
Re: Keyboard filler
« Reply #1 on: Fri, 27 December 2013, 14:13:08 »
It's just foam. You can use any foam or rubberized shelf liners.  Anything that's of a thickness that fits comfortably in the cavity between the PCB and the bottom of the case (might need some cut outs) should do well.  Shelf liners are easy to get in many hardware stores and even supermarkets.
Offline keymaster
Re: Keyboard filler
« Reply #2 on: Fri, 27 December 2013, 14:54:28 »
Thanks for the info. I'll be picking these up from Home Depot.
