Author Topic: New around here.  (Read 2320 times)
Offline JordanRinke
New around here.
« on: Fri, 27 December 2013, 18:47:03 »
Have lurked a bit (mostly through searches) but deciding to get in on some ergodox action and figured it would be worth while to become a member and start participating instead of just lurking.
Offline regack
Re: New around here.
« Reply #1 on: Fri, 27 December 2013, 19:02:45 »
Hi, welcome!  I still haven't finished building the left hand of my ergodox :(
Offline JordanRinke
« Reply #2 on: Fri, 27 December 2013, 19:08:50 »
Yeah, it looks like a lot of work to put together but... the finish product looks amazing. Especially since I want to try a modified colemak layout with layers, all the extra thumb buttons just look super handy. Thinking that with a trackball in the middle or something would be a pretty sweet productivity rig. I missed the recent massdrop kit buy though so looking for one for sale or a kit right now, that failing I will just source all the parts in the next week or two. There is so much information I am having trouble sifting through it now. Like... which key caps to get, or what profiles specifically etc. Much reading to be done.
Offline regack
« Reply #3 on: Fri, 27 December 2013, 19:17:30 »
There is a ton of ergodox info, but reading through all of the threads, yes... that will certainly take time :D
Offline 1pq
  • Hipster Doofus
« Reply #4 on: Fri, 27 December 2013, 19:46:28 »
Good choice! The ergodox looks really cool. I should try it sometime...
What switch are you thinking of using/getting?
Also, where's tp4 to congratulate you? :P
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
« Reply #5 on: Fri, 27 December 2013, 20:43:55 »
get hhkb and dont look back
Offline JordanRinke
« Reply #6 on: Fri, 27 December 2013, 21:07:33 »
I run a ducky shine 2 tkl with cherry blues right now and I like it. Thinking about trying to find some lighter spring for it which also seems like no easy task. If I get an ergodox I will either buy or build it with cherry blues as well (and the lighter springs if I can find them / get them made somewhere in Canada)
Offline 1pq
  • Hipster Doofus
« Reply #7 on: Fri, 27 December 2013, 22:11:30 »
*HHKB with dental band and 55g mod
not that I've ever used one lol
