Author Topic: this site looks decent  (Read 4594 times)
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« on: Thu, 05 February 2009, 16:43:39 »
On my new Treo 800 M.
Little crazy looking but I can manage. ;)
Offline bhtooefr
    • bhtooefr.org
« Reply #1 on: Thu, 05 February 2009, 22:29:08 »
800m? Umm, wrong button. :)
Anyway, try Opera Mobile. It can reformat the page so that you don't have to do horizontal scrolling. :)
Offline xsphat
  • Enlightened
« Reply #2 on: Thu, 05 February 2009, 23:19:39 »
Quote from: bhtooefr;20914
It is in fact an 800m. I like it because it feels like a computer instead of a phone. I was editing a .doc file on it today in Mobile Word — fantastic.
EDIT: Sorry, it's am 800w, not 800m.
Offline lowpoly
« Reply #3 on: Fri, 06 February 2009, 03:04:07 »
If you want to do a lot of .doc editing you might want to try Textmaker:
http://www.softmaker.com/english/ofp_en.htm
Offline xsphat
  • Enlightened
« Reply #4 on: Fri, 06 February 2009, 03:17:04 »
Thanks for the tip, I might check it out. Any others I should try?
Offline lowpoly
« Reply #5 on: Fri, 06 February 2009, 03:48:22 »
What I use most:
ListPro
Todo lists. I also use it to structure all kind of ideas and thoughts. It is basically a tree list. This is the only one that has unordered lists though. You can drag items up and down to reorder them.
eWallet
For all my passwords, credit cards etc. I use a long complicated password. If I lose my pda and someone finds it, it is unlikely they can crack the database on a PC.
iPhone: eWallet is also available for the iPhone, ListPro is in the works.
Sbp Backup.
Very important.
PhatPad
for scribbling/drawing notes. Not perfect but better than the others I tested. They also have a program that translates your scribbles into ascii but it didn't work for me.
PocketInformant
Calendar replacement.
MobiPocket
Ebook reader. They also have an ebook creator. Both are free. You can use the creator to convert .txt, .pdf or .html files to the mobipocket format.
Resco Photo Viewer
There is also a good free viewer, don't remember its name. The Resco viewer is faster though.
TotalCommander
Free file tool. I use a commercial one because I like the design better but TotalCommander is actually better.
If you want a video player get TCPMP.
I also have a lot of SlovoEd dictionaries as I usually read in English.
I also use Wisbar Advance and Wisbar Advance Desktop for task switching. Setting up Desktop is a lot of work though.
Offline xsphat
  • Enlightened
« Reply #6 on: Fri, 06 February 2009, 10:04:34 »
bhtooe, Opera mobile is pretty nice. Thanks!
