Author Topic: WASD V2 87 barebones MX Brown  (Read 8490 times)
Offline dante
« on: Tue, 31 December 2013, 22:40:24 »
So I have some mileage on this board ...
Pros:
+ Unlike the V1 Barebones all the metal clips were snapped into place already.
+ WASD is the only company with the balls to release a keyless keyboard at a discount: much street cred.
+ The only costar stabilized keyboard I've ever owned that has no space bar rattle.  I've tried several space bars and nothing!
+ No Ping!
+ If something goes wrong the owner of WASD will take good care of you.
Cons:
- No plastic keyboard dust cover.  Ducky, Leopold, Filco, and even Keycool offer one.
- Two little holes for the LED's which hide behind the keycaps: completely pointless.
- Just as on the V1 you can see the metal bars under the stabilized keys: kind of tacky.
- When WASD says "Low Profile" they mean low profile compared to the V1 - really not any lower profile then say a QFR.
- Should have kept it hardwired as I have the same issues every multi-channel keyboard I've ever tried: The cable eventually pulls out.
Other Thoughts:
\ Have had no issues with the micro-usb cable but if you read the reviews on the WASD site some people have had to get their modules replaced already.
Conclusion:
/ I bought this because it was marketed as a low profile keyboard. After some mileage I think a Cherry G80-3850 MX 3.0 is probably what I'll try next.
« Last Edit: Wed, 01 January 2014, 21:48:16 by dante »
Offline bazemk1979
Re: WASD V2 87 barebones MX Brown
« Reply #1 on: Wed, 01 January 2014, 18:17:02 »
cmon dude, pics.......
Offline Pacifist
  • on hiatus
« Reply #2 on: Wed, 01 January 2014, 18:35:17 »
What do you mean by: Two little holes for the LED's which hide behind the keycaps: completely pointless.?
Offline Belfong
« Reply #3 on: Wed, 01 January 2014, 19:18:50 »
The Caps Lock and Scroll Lock LED is just below the Print Screen, Scroll Lock and Break keys and they are really just two little holes. Very hard to notice - but I like it compare to the bigger light that some other keyboards use.
Edit: you can see this in the Code keyboard page.
Offline dante
« Reply #4 on: Wed, 01 January 2014, 21:27:47 »
As explained above I think WASD could have copied the Realforce 86U and just not included LED's at all.  Another place they could have snuck them in is on front of the keyboard by the space bar.
Added
« Last Edit: Wed, 01 January 2014, 21:47:58 by dante »
Offline terran5992
  • One With The Cup Rubber
« Reply #5 on: Thu, 02 January 2014, 01:40:05 »
You didnt opt for custom keycaps?
Offline dante
« Reply #6 on: Thu, 02 January 2014, 09:08:46 »
Nope.  Tai Hao look slightly thicker plus double shot.
Offline lilky
« Reply #7 on: Thu, 02 January 2014, 11:14:31 »
Could use more pics...interesting that the WASD doesn't have wobbly stabs or ping...
Offline zed
« Reply #8 on: Tue, 04 February 2014, 09:32:51 »
I don't think I would ever buy a WASD without custom keycaps but to each their own.
Offline bazemk1979
« Reply #9 on: Tue, 04 February 2014, 19:04:13 »
you should reconsider me thinks lol
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #10 on: Tue, 04 February 2014, 22:41:19 »
Conclusion:
Just would like to know from you the current WASD V2 TKL keyboard, which I'm presuming is a pcb-ONLY keyboard?
Please let me know.
Because you said you wanted to try out the new Cherry G80-3850 MX 3.0 keyboard which is a metal-plate setup, hence it will have a different feel when typing.
Offline Lu_e
« Reply #11 on: Tue, 04 February 2014, 23:43:42 »
WASD is plate mount
Just say NO to ABS keycaps
Offline Elrick
  • Hype Master
« Reply #12 on: Wed, 05 February 2014, 00:08:39 »
WASD is plate mount
Damn, that's sweet, so it's exactly like a Filco.....?
Offline dante
« Reply #13 on: Wed, 05 February 2014, 09:58:07 »
WASD is plate mount
No it's not.  WASD V2 = single PCB, WASD CODE = double PCB, Filco = double PCB
Offline bumgrapes
  • Poker II
« Reply #14 on: Thu, 13 February 2014, 12:20:39 »
Nice review! Just this second opened mine & my first impressions are good :D
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #15 on: Tue, 18 March 2014, 12:24:22 »
Dante, I don't have access to my WASD V2 atm but do you remember if the pcb had holes throughout on all the other switches for LED's? thanks
Offline dante
« Reply #16 on: Tue, 18 March 2014, 12:46:24 »
Sorry - I no longer have this keyboard.
Offline digi
  • elite af tbh
« Reply #17 on: Tue, 18 March 2014, 12:49:03 »
No worries, I'll crack it open when I get home and check it out, thanks for the reply.
