Author Topic: IBM Model M 122 terminal mod: unused barrel next to space.  (Read 1718 times)
Offline minium
« on: Thu, 02 January 2014, 00:04:48 »
Has anyone added a trace and gotten it to work?
Background: This is my first Model M and I have not even hooked it up. The teensy++ came in the mail the other day, but I ordered the wrong part and have to wait for a 6pin 240 degree to ship. In the meantime, I am doing a bolt mod and have torn the M122 down completely. There is a barrel between space and LALT, but the matrix doesn't have a intersection for that location. I'd like to extend a trace each from the upper and lower plastic sheets, cut down the space bar, put a key-spring-hammer and have it return LGUI from the keyboard controller through Soarer's converter to my computer. Has anyone added a trace and gotten it to work?
Offline Parak
Re: IBM Model M 122 terminal mod: unused barrel next to space.
« Reply #1 on: Thu, 02 January 2014, 00:28:15 »
That barrel is required to stabilize the spacebar better. If you cut down the spacebar it will be quite wobbly due to being unbalanced as well.
Offline terran5992
  • One With The Cup Rubber
« Reply #2 on: Thu, 02 January 2014, 01:03:16 »
I dont really get the question
Offline minium
« Reply #3 on: Thu, 02 January 2014, 01:53:19 »
Parak: That makes sense. I saw the empty barrel and got excited to have control, alt and command on the thumbs.
terran5992: I wanted to know if anyone else had modded the empty barrel next to the space bar to act as an additional key.
Offline berserkfan
« Reply #4 on: Thu, 02 January 2014, 07:44:34 »
there isn't a contact there, so I don't think anyone has done this. But since you're adding a trace, you will be the first guy and if you succeed, I think you will have lots of people asking for photos.
So please take LOTS of photos.
