Author Topic: What's differences between Poker X and Poker II?  (Read 3806 times)
Offline joneslee85
  • HHKB Scrub JP
  • Professional Rubyist programmer!
    • Ruby Journal
« on: Thu, 02 January 2014, 20:42:24 »
Hi all
I've been absent since the last 3 years. I could not find any info on Internet about Poker X (I assume this is what ppl called Poker I). So I would like to ask any experts here on the differences between Poker I vs Poker II.
Many thanks
UPDATE: got my answer
here is what I learnt:
Poker II is better than Poker X at:
* Better PCB design
* SMD components
* smaller controller (Nuvoton controller)
* comes with metal plate, thus switches are plate mount instead of PCB mount
* every key has diode, suggesting adding LEDs is possible
* include RGB modifier thick keycaps (extra)
* thick PBT keycaps
* programming mode
* direction key is now on the left at WASD instead on the right, this is a biggest change, but I like it
* new metallic label on bottom
* better case mounting
« Last Edit: Thu, 02 January 2014, 21:18:49 by joneslee85 »
TOO MANY KEYBOARDS THAT I COULD NOT COUNT! BUT I AM STILL USING MY MODEL F77
Offline Wildcard
  • When caffeine isn't enough
Re: What's differences between Poker X and Poker II?
« Reply #1 on: Thu, 02 January 2014, 20:54:08 »
WFD covers it pretty well here.
TL;DR
Added programmability, plate, thick stock PBT keycaps, better case mounting.
Offline joneslee85
  • HHKB Scrub JP
    • Ruby Journal
« Reply #2 on: Thu, 02 January 2014, 21:09:00 »
* Better PCB design
* SMD components
* thick PBT keycaps
* programming mode
« Last Edit: Thu, 02 January 2014, 21:18:22 by joneslee85 »
Offline terran5992
  • One With The Cup Rubber
« Reply #3 on: Fri, 03 January 2014, 00:14:45 »
So buy the poker II?
« Reply #4 on: Fri, 03 January 2014, 00:19:51 »
Hmm I thought everyone loved poker x though?
Offline dragonxx21
« Reply #5 on: Fri, 03 January 2014, 00:38:25 »
IIRC Poker X is just the original Poker.
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
