Author Topic: Whats a Good Cheap Mic?  (Read 4216 times)
Offline Pacifist
  • on hiatus
« on: Thu, 02 January 2014, 21:11:08 »
I need a standalone mic. ****ty headset mic doesn't cut it. Sub $20 would be ideal? Anybody have any favorites?
Offline regack
Re: Whats a Good Cheap Mic?
« Reply #1 on: Thu, 02 January 2014, 21:16:32 »
Never mind - out of the price range
« Reply #2 on: Thu, 02 January 2014, 21:43:30 »
Offline Pacifist
  • on hiatus
« Reply #3 on: Thu, 02 January 2014, 21:46:36 »
http://www.amazon.com/Zalman-Zm-Mic1-Sensitivity-Headphone-Microphone/dp/B00029MTMQ
and then any pair of headphones you want
I thought these were discontinued :eek:
But now they're not as cheap as before
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« Reply #4 on: Thu, 02 January 2014, 21:46:37 »
that microphone sucks ****. the clip doesn't fit on any normal sized headphone wires, and the mic's sensitivity will pick up every ****ing noise in your room. would not recommend.
« Reply #5 on: Thu, 02 January 2014, 22:09:50 »
fits on my ad700s just fine
Offline kmiller8
« Reply #6 on: Thu, 02 January 2014, 22:13:13 »
now tell me all the headphones you own it doesn't fit on.
« Reply #7 on: Thu, 02 January 2014, 22:21:59 »
fits all of them
« Reply #8 on: Thu, 02 January 2014, 22:22:56 »
I have Logitech one that's served me well for a couple years. I use it often for recording voice-overs and foley effects for games and it has great sensitivity. I think it was like $30 something though, but it was worth it.
Offline kolonelkadat
  • Location: the vicinity of an area adjacent to a location
    • Force Project X
« Reply #9 on: Thu, 02 January 2014, 22:49:27 »
I pulled the mic out of a telephone. put it in a plastic tube left over from soldering. soldered on wire from broken headphones. wrapped an aircon filter around it for a dead cat (which it desperately needed.) total cost was under 5 bucks. mad decent quality for what it is imo.
"Obviously, windows are central to Windows. But what is a window?"
« Reply #10 on: Thu, 02 January 2014, 22:57:51 »
Offline Badwrench
  • ummmm.....I forgot
« Reply #11 on: Thu, 02 January 2014, 23:10:28 »
I have one of these:  http://www.amazon.com/Cyber-Acoustics-ACM-1b-Monitor-MicrophoneLapel/dp/B0000511GQ/ref=pd_sim_sbs_e_20.  Good little mic for $6.  I used to have it mounted on the top edge of my monitor, but the double sided tape is long gone, so now it just sits under the front edge of my monitor.  Works perfectly and everyone I game with can hear me loud and clear.
49750-0
Offline Parak
« Reply #12 on: Thu, 02 January 2014, 23:14:08 »
Labtec LVA7330 (google around for mods with it)
Offline Parak
« Reply #13 on: Thu, 02 January 2014, 23:14:55 »
Offline Snigeln
« Reply #14 on: Thu, 02 January 2014, 23:23:01 »
HHKB Pro JP Ducky Mini Ducky G2Pro
Offline godly_music
« Reply #15 on: Sun, 05 January 2014, 19:46:57 »
Zalman does not suck. It has quite good clarity for a lil' plastic piece of **** and will go along with a good pair of headphones. If the clip doesn't fit to the cable, maybe it'll fit to your collar? I end up doing that a lot.
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #16 on: Sun, 05 January 2014, 19:51:54 »
If attachable headphone mics are your thing, I've heard good things about modmic. Currently OOS tho
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #17 on: Mon, 06 January 2014, 09:43:47 »
Just get a freaking Antlion Modmic and be done with it! I'm telling you right now, it's on point!
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #18 on: Mon, 06 January 2014, 10:24:13 »
Waiting on the 4.0, needs dat mute button
Offline Gupgup
« Reply #19 on: Thu, 23 January 2014, 13:05:54 »
Dynex makes really good standalone microphones, I got one for less than 15$ with shipping on eBay.
Offline HPE1000
  • Keycap Paparazzo
« Reply #20 on: Thu, 23 January 2014, 13:08:41 »
That is what I use, I love it.
