Author Topic: where to find blank white dsa keycaps?  (Read 3870 times)
Offline mapple
« on: Fri, 03 January 2014, 03:03:02 »
fellow geekhackers as in topic nothing more to add.......  it would be perfect if they were translucent based on white backlight on my keyboard.... anyone god any clue?
In God We Trust
Re: where to find blank white dsa keycaps?
« Reply #1 on: Fri, 03 January 2014, 03:43:56 »
Offline mapple
« Reply #2 on: Fri, 03 January 2014, 04:26:53 »
Top 'o the page:
http://keycapsdirect.com/marketplace.php
k thanks, you think that they will be translucent, or maybe u already have them?
In God We Trust
Offline tbc
« Reply #3 on: Fri, 03 January 2014, 04:56:45 »
not translucent.  never seen translucent dsa before.
Offline mapple
« Reply #4 on: Fri, 03 January 2014, 06:20:10 »
well i'll order anyways. Hopefully some of light will go thru that:D (i'm giving that hope cause white lights went thru grey pbt not that much but still ... there's that hope.......)
In God We Trust
Offline MKULTRA
  • telling it how it is
« Reply #5 on: Fri, 03 January 2014, 06:56:22 »
SP caps are pretty thin.  The light tends to shine thru the caps.
« Reply #6 on: Fri, 03 January 2014, 18:19:08 »
If you can turn the brightness of your LEDs up, you should see at least some glow under the top of the keycap.
Worst case you will have a diffused glow coming from under the keycaps - that can look really cool :)
Offline Photoelectric
« Reply #7 on: Fri, 03 January 2014, 18:40:41 »
DSA caps are not as thin as DCS.  But with PBT, I'm pretty sure the white PBT will let a fair amount of LED glow through, and black will be mostly opaque.
« Reply #8 on: Fri, 03 January 2014, 19:33:58 »
I read in the DSA Retro GB thread that those ones pretty much don't let any light through.
I would imagine that the white ones would let some light through.
Also any light leaking through would be more consistent with DSA as all the keycaps are the same profile, compared to DCS where more light shines through the bottom row as the keycaps are much shorter.
« Reply #9 on: Fri, 03 January 2014, 19:35:52 »
Retro was dark ABS, and doubleshot at that, which is definitely very opaque.  Based on reports about IMSTO's thick PBT, which comes in light and dark varieties, light colored PBT lets a lot of light through, and dark, such as dark gray, does not let almost any light through.  Same with Ducky's light yellow thick PBT caps.
« Reply #10 on: Fri, 03 January 2014, 19:37:27 »
Yeah, I'm looking at Ducky yellow PBT keycaps as I type this :)
