Author Topic: Keycool 84 key cap sets  (Read 3149 times)
Offline catbuster
  • Fusion is Future
« on: Fri, 03 January 2014, 10:42:54 »
So i am about to order kc84 for my mmorpg needs  :p
Any place to look for key cap sets witch fit on this keyboard?
Poker 2 (black) 60% mx red
Offline nzhao20
Re: Keycool 84 key cap sets
« Reply #1 on: Fri, 03 January 2014, 17:04:00 »
banggood keycaps fit on them
Offline terran5992
  • One With The Cup Rubber
« Reply #2 on: Fri, 03 January 2014, 23:11:20 »
Seems like you need some 1x keycaps for the bottom row
You can find them at WASDkeyboards
Offline Pacifist
  • on hiatus
« Reply #3 on: Fri, 03 January 2014, 23:12:43 »
any reg tkl set+tsang will work(specifically 1.75x shift and 1x alt fn ctrl)
source: i own a kc84
Offline terran5992
« Reply #4 on: Fri, 03 January 2014, 23:13:37 »
Its hard to find tsangan kit to match the keyset unless you participate in a Group buy
Offline Pacifist
  • on hiatus
« Reply #5 on: Fri, 03 January 2014, 23:29:10 »
And most keysets come from group buys. The only ones that don't are ****ty sets ie banggood, wasd, all those junk sets that people usually don't use after getting a set from a group buy
Offline catbuster
  • Fusion is Future
« Reply #6 on: Sat, 04 January 2014, 05:01:13 »
Thx! ^^ now i need find good GB  for dis
