Author Topic: Poker X  (Read 3615 times)
Offline Comment
Poker X
« on: Fri, 03 January 2014, 23:50:13 »
Does anyone know where you can still buy a Poker X? I've been looking but can't really find it anywhere. I was going to post a WTB thread but I am too new of a member. Anyone with any knowledge on this would be awesome!
Check out my WTB/WTS/WTTF Thread!
   HHKB Pro 2                 Noppoo Choc Mini
Offline Pacifist
  • on hiatus
Re: Poker X
« Reply #1 on: Fri, 03 January 2014, 23:51:15 »
Its pretty much discontinued. Either classifieds(in which you stay here and get 60 meaningful posts) or get the newer version the poker II
Offline Comment
Re: Poker X
« Reply #2 on: Fri, 03 January 2014, 23:54:16 »
Yeah that's what I figured, but is there a Poker 2 that is PCB mounted?
Offline Permeability
Re: Poker X
« Reply #3 on: Sat, 04 January 2014, 00:06:57 »
I don't think so, they are all Plate mounted
Keyboards:
'The Cheat' - lubed 62g Clears
Ducky Shine 3 TKL lubed 45g Reds (Work)
Offline Comment
Re: Poker X
« Reply #4 on: Sat, 04 January 2014, 00:08:52 »
Do you know what I lose by having a plate mounted board as opposed to a PCB? Can you still change the spring/stems of keys?
Offline Pacifist
  • on hiatus
Re: Poker X
« Reply #5 on: Sat, 04 January 2014, 00:09:56 »
You have to desolder it to change stuff
unless you get a custom plate
but then you have to desolder, apply plate, and then resolder, which you may or may not like
but for feelings plate is def better
Offline Comment
Re: Poker X
« Reply #6 on: Sat, 04 January 2014, 00:55:46 »
Okay so it seems my best bet is to say screw it and get the poker 2. Odds are that I wont be removing the stems or springs themselves but i will be wanting to wire for leds and im sure theres a thousand guides out there on how to do it on a Poker 2. Everyone says the plate is better for feeling so I really dont see a downside to getting the Poker 2 over the Poker X anymore.
Offline Pacifist
  • on hiatus
Re: Poker X
« Reply #7 on: Sat, 04 January 2014, 01:00:19 »
to wire leds you just put it through the hole in the front of the switch and then solder on the backend. pretty simple
Re: Poker X
« Reply #8 on: Sat, 04 January 2014, 04:18:33 »
Some do prefer PCB mount switch over plate mount as it expresses switch feeling differently.
Also you can buy backlit poker 2 now.
I'm on my phone or else I'd provide links, but there have been a few write ups on adding LEDs to non backlit poker 2 if you just want a project.
Offline joneslee85
  • HHKB Scrub JP
  • Professional Rubyist programmer!
    • Ruby Journal
Re: Poker X
« Reply #9 on: Sat, 04 January 2014, 05:51:30 »
Please keep in mind that Poker X direction keys are on the right keys whilst poker II is on ASWD keys. Plus the thick PBT caps of Poker II is very nice addition. I highly recommend you buy the thick PBT version of Poker II and then customise
TOO MANY KEYBOARDS THAT I COULD NOT COUNT! BUT I AM STILL USING MY MODEL F77
Offline TheSoulhunter
  • ~ BOOO ~
Re: Poker X
« Reply #10 on: Sat, 04 January 2014, 08:36:38 »
What switch are you looking for? I have some NIB Pokers around, would be willing to trade it for a Poker2 with Blacks...
A Ghost From The Past
Offline Neal
  • Skype: iNewbcake
Re: Poker X
« Reply #11 on: Sat, 04 January 2014, 09:01:48 »
Mine has both...? Is that normal, thought it was supposed to be like that.
Offline zoolzoo
Re: Poker X
« Reply #12 on: Sat, 04 January 2014, 20:51:39 »
Poker X arrows can be set to WASD.
http://webwit.nl/input/misc/poker/usermanual.pdf
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
Re: Poker X
« Reply #13 on: Sat, 04 January 2014, 21:04:11 »
I'm having a really hard time deciphering this manual. What's the sequence to set arrows to WASD?
Offline Neal
  • Skype: iNewbcake
Re: Poker X
« Reply #14 on: Tue, 07 January 2014, 22:20:14 »
Holding down Fn will have WASD function as arrows.
Offline ideus
  • Björkö.
Re: Poker X
« Reply #15 on: Tue, 07 January 2014, 22:46:06 »
WASD as arrows keys in the Poker X can be inloked with chorded FN+WASD but they cannot be set.
