Author Topic: TteSports KB-MEK review  (Read 8225 times)
Offline kilogeek
  • Nostalgy of a time when quality was a value
« on: Sat, 04 January 2014, 19:00:44 »
I bought one on Amazon, had a bad printed key (90°) and anyway could not use such compact layout :
http://www.amazon.fr/gp/product/B00ATXXIPM/ref=oh_details_o04_s00_i00?ie=UTF8&psc=1
So returned it but had time to test it in depth, with disassembly.
Global feeling is : robust keyboard, heavy, strong plastic case, metal pane.
So, what's wrong ?
What I find wrong with this keyboard is what I don't like with many  new MX-type keyboards, keycaps are crap, made of very light plastic, just fitted on the MX switches cross guide, I find this a bad design. MX are not the problem, but if you just fit a cap on them, you get lateral movements, you may even get keys blocking when pressed on borders, not stabilized. This cross is tiny, if you don't press at the center of the key, MX switch won't like it...
On this particular keyboard :
- Layout is weird IMO, there is one lost key up-right of arrows keys... strange,  hard to use
- Leds on lock keys is a good idea but these leds are much too lightning, it's almost painfull for eyes^^
- Letters seem sticked on keys and letter font/types are not consistant (looks like fast work made with illustrator...)
- This my only taste but I don't like MX black, in fact although I did not test all MX colors, the fact they use a linear spring means you need more force to hold a key down than to start pressing a key, I don't like this, buckling spring or high-end domes don't feel the same and it's much better IMO, even for gaming (some games require you to keep keys pressed for a while, W.O.T. for example)
This keyboard is very affordable for a mechanical but I would recommand you to test it before buying, looks nice on pics but you may not find it so nice to use...
(I find my new Compaq RT102 far much better and I had it for only 5 euro, I disassembled it and can definitely tell it's a high-end design and manufactured keyboard, even if it's not using springs)
My next review may be on the EPSON/FUJITSU 8720 clicky keyboard, the seller sent me pics of a keycap, made of 2 parts, even better than the model M caps : a cylinder and 2 other guides on key corners, I'll take pics while cleaning it.
ADD : forgot to mention that like many MX keyboards, this one do not use metal stabilizers for long keys, instead it uses additionnal plastic guides, it could be worst, but it's not as efficient as traditionnal metal stabilizers found on old keyboards.
« Last Edit: Sat, 04 January 2014, 21:41:29 by kilogeek »
"Ne pas subir" - Devise de Saint-Cyr.
Offline tbc
Re: TteSports KB-MEK review
« Reply #1 on: Sat, 04 January 2014, 21:51:55 »
yep, one of the worst layouts ever conceived with no hope of fixing.
instant fail.
Offline funkymeeba
  • CRUMPULAR
  • WEST SHINJUKU PLANTING TUNE
« Reply #2 on: Sat, 04 January 2014, 23:39:38 »
I just can't stop laughing at the placement of the ?/ key. It's almost beautiful how off that is.
17:15 < vun> these are the healthiest crisps I've ever come across
17:16 < vun> mostly because I can't get the bag open
meebcats - my bad music
Offline kilogeek
« Reply #3 on: Sun, 05 January 2014, 06:20:17 »
at least on this one there is a numpad... layouts without numpad may be ok for US or EN QWERTY kb but not for many other languages, certainly not for french, using very often é,è,à,ç,ù letters and not only these, numpad is a must-have for us, I almost never use numbers on the left part of the keyboard... and many games use numpad keys as default shortcuts too.
Offline clickclack123
« Reply #4 on: Mon, 06 January 2014, 20:59:37 »
Haha true! I use the dvorak layout, and using dvorak, that would be the "z" key.  :eek:
Other than that I'd like that layout I think though. I ended up buying a CM Storm Quickfire TK which hasn't arrived yet but is sort of a similar layout except the arrow keys.
Offline Linkbane
« Reply #5 on: Mon, 06 January 2014, 22:10:36 »
Like clickclack said, you might want to try the TK! Similar shape, but very different layout; the numpad has a '00' key and with numlock off you can use 2, 0, 00, and . as arrow keys; it works and is quite ingenious in my opinion.
I use Dvorak also; I can't believe that one could botch a layout so badly.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline lilky
« Reply #6 on: Sat, 11 January 2014, 14:56:34 »
What in the... this layout ಠ_ಠ
Offline davkol
  •  Post Editing Timeout
« Reply #7 on: Thu, 16 January 2014, 07:01:39 »
It was supposedly designed for playing SC2... Ugh.
Anyway, switches feel quite good (light like on the other Tt keyboards), but stabilizers are **** (dat big-ass enter) and once again, the layout is just retarded. Otherwise a solid keyboard, but I don't see any reason to get it except with some ultimate discount.
Offline berserkfan
« Reply #8 on: Tue, 04 February 2014, 09:41:13 »
So, what's wrong ?
This is one of the models I dislike the most. Yes, the horrible keycaps, and also the ancient, outdated return key. Nobody else uses such a damn enter key anymore and you can't get replacement keycaps.
Offline Candyflip
« Reply #9 on: Tue, 04 February 2014, 10:17:00 »
Small backspace, huge enter, unnecessary big ctrl and that /? position... no! I think the spacing in the function row is odd too...
Offline davkol
« Reply #10 on: Fri, 14 March 2014, 15:03:38 »
Okay, here's one thing I didn't notice before. The keyboard has not only non-standard slash key placement, weird layout and big-ass enter, but also
  • 2.25x left Control (the size of a standard Shift key) and
  • 2x Shift keys, both of them, which results in non-standard staggering (the ZXCV alpha row is moved 0.25x to the left).
Offline berserkfan
« Reply #11 on: Sat, 15 March 2014, 07:24:21 »
instant fail.
Model F XT is far superior in layout to this retarded crap. How do they even stay in business? Their fans are even more fanatical than Razer's?
Offline wetto
  • Brazil's Keyboard Enthusiasts Representative
    • Portuguese Mechanical Keyboard Guide
« Reply #12 on: Sat, 15 March 2014, 13:01:50 »
It also has one of the worst keycaps and laser printing I've ever seen on a keyboard.
ABNT2 (Brazilian Portuguese) layout is a bit more "acceptable" than its US counterpart.
instant fail.
They can't. That's why they removed themselves from the Mechanical Keyboard market here in Brazil, along with huge losses because they had to cut their prices in half just to make the keyboards that were being "sold" (more like "stocked") since 2012 get off the shelves.
Our market over here is very limited (Razer, CM Storm, Corsair and the new ones: Roccat, Tesoro and A4Tech), but even still, I really won't miss them.
« Last Edit: Sat, 15 March 2014, 13:19:43 by wetto »
My collection:
Mice: Logitech G602, CM Storm Recon, CM Storm Spawn, Razer Naga, Ozone Radon Opto, Corsair M60, Tesoro Gandiva, CM Storm Alcor, Mionix Naos 8200.
Keyboards: Matias Secure Pro, Matias Mini Quiet Pro, custom modded Metadot Das Keyboard Model S Professional Silent (MX Brown, Costar), CM Storm Trigger (MX Brown), Noppoo Choc Mini (MX Red), Tesoro Lobera G5NFL Supreme, CM Storm Devastator.
Soon: CM Storm Quick Fire TK (MX Brown), CM Storm Trigger Z.
Boards I don't own anymore: CM Storm Quick Fire Rapid (MX Black), Logitech K800 (Membrane), Logitech G710+ (MX Brown), Thermaltake Meka G-Unit (MX Black), Corsair K70 (MX Red).
Mice I don't own anymore: Logitech G9x MW3, Corsair M65, Logitech G700, Roccat Kone Pure.
Offline davkol
« Reply #13 on: Sat, 15 March 2014, 13:20:09 »
wat.
Those 1x shifts, is it a joke?
Offline wetto
« Reply #14 on: Sat, 15 March 2014, 13:39:11 »
wat.
We're used to 1x1.25 on the left and 1x1.75 on the right on our keyboards, so, 1x1 at least for the left one isn't that much of a big deal.
Standard ABNT2 layout:
« Last Edit: Sat, 15 March 2014, 13:42:30 by wetto »
My collection:
Offline davkol
« Reply #15 on: Sat, 15 March 2014, 13:40:40 »
AFAIK Meka was designed for SC2 or something along those lines. Using 1x shifts sort of defeats that original purpose.
Offline wetto
« Reply #16 on: Sat, 15 March 2014, 13:47:54 »
As far as I know, the Meka is just a redesigned i-Rocks KR 6230
More gimmicks, same flaws  :))
My collection:
Offline davkol
« Reply #17 on: Sat, 15 March 2014, 14:06:47 »
What was first though? Tt could design a keyboard and ask Solid Year to make it, while approving rebranded use.
