Author Topic: Clarifications on my collection  (Read 4943 times)
Offline BigWopHH
    • http://www.hothardware.com
« on: Sat, 07 February 2009, 18:13:17 »
I'm still wasting money, trying to figure out which is my favorite keyboard, but wanted to make sure I was correct on the switch types for each.  Here's what I've got, and what I understand the switch types to be...
ABS M1 - Black Alps Copies
Solidtek ASK-6600U - Simplified Alps Copies (Color?)
Dell AT101W (non-clicky) - Alps Black
Das III Pro - Cherry Blue
Scorpious M10 - Cherry Blue
Unicomp Customizer 104 - Buckling Spring
Cherry G80-3000LSCRC-2 - Cherry Blue
Am I misunderstanding anything here?  Are there any details I'm missing?  Proper switch names, etc?
  • Topre Realforce 103UB
  • Topre Realforce 87U
  • ABS M1
  • Solidtek ASK-6600U
  • Dell AT101W
  • Das III Pro
  • Scorpious M10
  • Cherry G80-3000LSCRC-2 (Blues)
  • Cherry G80-3000LXCEU-2 (Browns)
  • Unicomp Customizer 104
  • Steelseries 7G
  • Filco Majestouch FKBN104M/EB < Has Become My Daily Driver. Really Diggin\' It.
[/SIZE]
Offline bhtooefr
    • bhtooefr.org
« Reply #1 on: Sat, 07 February 2009, 18:15:52 »
ABS M1 is simplified fake Alps, black.
Not sure on the Solidtek.
I may be wrong, but the AT101W is real complicated Alps, in black?
Everything else is right, although I'll add that the Cherries are specifically MX switches.
Offline zwmalone
« Reply #2 on: Sat, 07 February 2009, 18:18:19 »
The SolidTek ASK-6600U has white ALPS.
Can't get enough of them ALPS
Offline BigWopHH
« Reply #3 on: Sat, 07 February 2009, 18:28:16 »
OK, cool.  So just to be sure here's the revised list with your input / corrections...
ABS M1 - Alps Copies (Black)
Solidtek ASK-6600U - Simplified Alps Copies (White)
Dell AT101W - Alps Complicated (Black)
Das III Pro - Cherry MX (Blue)
Scorpious M10 - Cherry MX (Blue)
Cherry G80-3000LSCRC-2 - Cherry MX (Blue)
Almost forgot.  The Steelseries 7G, that is also an Alps Copies (Black) board, correct?
  • ABS M1
  • Dell AT101W
  • Das III Pro
  • Scorpious M10
  • Steelseries 7G
[/SIZE]
Offline zwmalone
« Reply #4 on: Sat, 07 February 2009, 18:30:11 »
I'm pretty sure the steelseries has high-force Cherry MX Blacks which are linear.
Offline lam47
« Reply #5 on: Sat, 07 February 2009, 19:08:10 »
7G has cherry mx blacks 100%
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline BigWopHH
« Reply #6 on: Sat, 07 February 2009, 19:32:41 »
Great.  Thanks for the help everyone.  Ok, here's the final rev. if all is correct...
ABS M1 - Alps Copies (Black), Tactile, Non-Clicky
Solidtek ASK-6600U - Simplified Alps Copies (White), Tactile, Clicky
Dell AT101W - Alps Complicated (Black), Tactile, Non-Clicky
Das III Pro - Cherry MX (Blue), Tactile, Clicky
Scorpious M10 - Cherry MX (Blue), Tactile, Clicky
Cherry G80-3000LSCRC-2 - Cherry MX (Blue), Tactile, Clicky
Unicomp Customizer 104 - Buckling Spring, Tactile, Clicky
Steelseries 7G - Cherry MX (Black), Tactile, Non-Clicky
  • ABS M1
  • Dell AT101W
  • Das III Pro
  • Scorpious M10
  • Steelseries 7G
[/SIZE]
Offline bhtooefr
    • bhtooefr.org
« Reply #7 on: Sat, 07 February 2009, 20:00:21 »
No, the black MXes are linear, so not tactile OR clicky.
And, the M1 is simplified (IIRC, all fake Alps are.)
Offline BigWopHH
« Reply #8 on: Sat, 07 February 2009, 20:03:58 »
Got it.  Quick follow up question.
Why is a linear switch not tactile?  As long as there is some resistance to a key press, aren't all switches tactile?
  • ABS M1
  • Dell AT101W
  • Das III Pro
  • Scorpious M10
  • Steelseries 7G
[/SIZE]
Offline bhtooefr
    • bhtooefr.org
« Reply #9 on: Sat, 07 February 2009, 20:10:25 »
Get a hold of some Cherry browns or clears, you'll see what I mean.
Offline lam47
« Reply #10 on: Sat, 07 February 2009, 20:13:33 »
I was confused about this too.
The use of the term tactile is not strictly correct in keyboard circles.
Tactile in switches means you can feel a bump in the travel of the switch.
It can click or not click but tactile in switches is not the 'feedback' from the spring.
Offline BigWopHH
« Reply #11 on: Sat, 07 February 2009, 20:16:46 »
That clears thing up.  I was under the impression that if the switch provided the key-press resistance it was tactile.  Thank for the clarifiation, I really appreciate it.
  • ABS M1
  • Dell AT101W
  • Das III Pro
  • Scorpious M10
  • Steelseries 7G
[/SIZE]
Offline zwmalone
« Reply #12 on: Sun, 08 February 2009, 10:12:51 »
Quote from: BigWopHH;21122
If I were you I'd get a Cherry G80 instead of either the scorpius or the Das.  The Scorpius has a high defect rate (broken traces, bad soldering, fixing stuff with glue, etc).  The Das has severe rollover issues and problems with the plastic and build quality of the case.
Offline skriefal
« Reply #13 on: Sun, 08 February 2009, 10:34:57 »
I believe that's a list of the keyboards that he already owns.
Looks like the next purchase options might be a board with brown Cherry switches (or black, but those aren't well-liked) or a Topre or HHKB.  But on the used market there are many other options to try including real bigfoot white/blue Alps (old Northgate Omnikey 102, etc), damped Alps (Apple Extended II, some SGI), linear Alps (yellow/green), or even the less common switch options from NMB, NEC, etc.
Offline bhtooefr
    • bhtooefr.org
« Reply #14 on: Sun, 08 February 2009, 10:35:00 »
As I understand, he actually already owns all three. ;)
Offline BigWopHH
« Reply #15 on: Sun, 08 February 2009, 10:37:27 »
Quote from: zwmalone;21153
I actually do own all of these alreadly.  Some were samples, and others I wanted to try based on information I've read here.
And I know what you mean about the Scorpius.  I'm still waiting on the second one, becuase my first was defective.
  • ABS M1
  • Dell AT101W
  • Das III Pro
  • Scorpious M10
  • Steelseries 7G
[/SIZE]
Offline zwmalone
« Reply #16 on: Sun, 08 February 2009, 10:41:43 »
Oh, I didn't realize you'd already purchased all these 'boards.  What a collection!  Sorry about your scorpius though.  It seems to be a hit-and-miss situation with them, you either get a good one or it comes defective...
Offline bhtooefr
    • bhtooefr.org
« Reply #17 on: Sun, 08 February 2009, 10:44:39 »
Mine was apparently one of the good ones, although it had no feet on it when I bought it. (Granted, I'm the third owner of it, and that was disclosed to me before I bought it.)
Offline BigWopHH
« Reply #18 on: Sun, 08 February 2009, 18:38:42 »
Quote from: bhtooefr;21158
I only got to use my first scorpius for a day before I realized one key was broken and the space bar began sticking.  If the replacement is a good one, I have a feeling that'll be the board I end up using daily.  Either that or the G80-3000.  Getting to the point where I think the Cherry blues are my favorite, but this Solitek board is pretty nice to type on.  The ringing is another matter though...
  • ABS M1
  • Dell AT101W
  • Das III Pro
  • Scorpious M10
  • Steelseries 7G
[/SIZE]
