Author Topic: Hello  (Read 1648 times)
Offline cdosborn
    • cdosborn
Hello
« on: Sun, 05 January 2014, 11:09:35 »
Hello!
I'm a student at the University of Washington, Seattle. I'm currently interested in purchasing a Filco Ninja Majestouch 2.
Offline wincent
Re: Hello
« Reply #1 on: Sun, 05 January 2014, 15:35:57 »
It's a nice keyboard. I've had one for about 18 months (with blue switches).
Feels great to type on. The build quality is high and the keyboard has a pleasantly weighty feel to it. The case has a minimal, simple design which I like. Easy to clean.
The only negative I've observed in 18 months of use is that some of the keys are starting to show signs of shininess (specifically, the oft-used space bar and left shift key, which I abuse).
Offline TheHardkaare
Re: Hello
« Reply #2 on: Mon, 06 January 2014, 09:57:36 »
Welcome to GeekHack fellow mech-enthusiast.
Offline epzy
  • HHKB Fiend
  • ded
Re: Hello
« Reply #3 on: Mon, 06 January 2014, 10:01:17 »
Shining will occur on any stock ABS caps, hence why you should swap them out for a better typing experience.
