Author Topic: What is this rubber thing for?  (Read 2195 times)
Offline Springfox
    • Springfox Software and Design
« on: Sun, 05 January 2014, 13:57:49 »
In my quest to find the perfect keyboard I think I've found it, around 20 keyboards later might I add, I've landed on the Noppoo Choc Mini with Blue Switches, (very reasonable price to in the UK from Amazon)
Though, in the box I received something I've never seen before, this rubber key cover, it fits perfectly on the keys and you can type through it really well which is something I've actually grown to quite like when I need to typing a little quieter (When I take it to the office).
However, I just wanted to know, what actually is it for? Am I even meant to be typing with it on?
Re: What is this rubber thing for?
« Reply #1 on: Sun, 05 January 2014, 13:58:24 »
Dust/Anti-spill Cover. Remove it before you type, put it back on so dust and other stuff doesn't get on your keyboard when you step away. If you type with it on, it feels like a bad version of the TG3's rubber mat thingy.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #2 on: Sun, 05 January 2014, 14:07:30 »
Emergency Condom
« Reply #3 on: Sun, 05 January 2014, 22:32:41 »
My Ducky has something similar, but it is thin but rigid plastic.  Keeps the dust off really well.
I just use a tea towel on my other keyboards.
Offline blueSmoke
  • Life is what happens while you're busy Fixing RSI
« Reply #4 on: Mon, 06 January 2014, 00:04:00 »
Looks very useful. Anybody know where we can buy these for tenkeyless boards?
Model M, Filco Tenkeyless White, Few others, few more others, Noise-hater (ongoing project), blah-blah (to be fillled later...)
Offline eddie
« Reply #5 on: Mon, 06 January 2014, 00:12:14 »
I recently purchased a Noppoo choc mini for myself for christmas and I received the same thing. I guess it's just a dust cover. At least that's what I use it for...
Offline ideus
  • Björkö.
« Reply #6 on: Mon, 06 January 2014, 00:48:03 »
A fancy packaging material, that happens to make a good dust cover.
Offline IPT
  • Formerly projectD
« Reply #7 on: Mon, 06 January 2014, 01:38:18 »
my leopold 700R came with one too.
Offline Mr. C
« Reply #8 on: Mon, 06 January 2014, 23:32:40 »
I've always called them keyboard condoms. For safe keyboarding.
Offline davkol
  •  Post Editing Timeout
« Reply #9 on: Wed, 08 January 2014, 14:39:28 »
Oh, I want one! I have it on my typematrix and it's great for blocking the upstroke noise as well as limiting the amount of dust that gets into the gaps between keycaps.
