Author Topic: [IC] Thick PBT SA Profile legend-less white Ergodox set  (Read 6925 times)
Offline Talfrey
« on: Sun, 05 January 2014, 15:20:16 »
I have been wanting to get a blank set of the deliciously thick SA profile keys for my Ergodox, and Signature Plastics can provide. I am reasonably confident that other geekhackers would be interested, so I am performing an interest check to see if anyone else would be interested so we can get a lower price point.
Looks like:
And will be priced as follows:
5 sets                      $78.12 per set
10 sets                   $62.83 per set
15 sets                   $57.73 per set
25 sets                   $53.66 per set
50 sets                   $50.60 per set
75 sets                   $49.58 per set
100 set                   $49.07 per set
150 sets                 $48.56 per set
200 sets                 $48.31 per set
250 sets                 $48.15 per set
Re: [IC] Thick PBT SA Profile legend-less white Ergodox set
« Reply #1 on: Sun, 05 January 2014, 15:22:02 »
SP can do SA profile PBT caps? I'm genuinely curious. I don't actually know @.@.
Offline Moosecraft
  • HHKB Pro
« Reply #2 on: Sun, 05 January 2014, 15:31:08 »
Would be pretty cool with SA normal set in pbt
Offline vivalarevolución
« Reply #3 on: Sun, 05 January 2014, 16:26:55 »
Yea, they have PBT SA profile.  I bought a couple.  Just check their inventory.
Offline Talfrey
« Reply #4 on: Sun, 05 January 2014, 19:19:36 »
Yes! In fact, I can provide screen shots of what they look like if you would like. They're quire nice. I don't have a full set however ;P
I have no normal keyboards, so I wouldn't have an interest in organizing such a GB, sorry!
« Reply #5 on: Sun, 05 January 2014, 20:03:27 »
You may not have any normal keyboards, but a lot of us do.
Maybe run a GB for a "normal" keyboard and then have an ergodox kit as an add-on?
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #6 on: Sun, 05 January 2014, 20:15:15 »
There are already plenty of "normal" keycap sets to choose from
« Reply #7 on: Sun, 05 January 2014, 20:19:15 »
But not in SA profile PBT.
Offline ShriekBob
« Reply #8 on: Mon, 06 January 2014, 09:20:46 »
I think basic economics suggests that TacticalStache is probably right, the way to go would be to split the set in to the "Alphas" and "Ergodox Mod", then add the mods for standard keyboards.  At the very least it might drop the price on the Alphas for the Dox.
Also, I'm interested.  I'd prefer them with legends, but I want two sets of caps for the Dox I'm building, one low, one high, and this seems like a good high profile set (unless someone does a KT profile set).
Offline zed
« Reply #9 on: Wed, 29 January 2014, 13:24:30 »
Awesome! I still think the GB will get a lot of attention because I mean there are very few Ergodox sets available.
Offline nkzt
  • DIY dye-sub explorer
    • Keycap DIY
« Reply #10 on: Wed, 29 January 2014, 17:12:59 »
I want PBT SA profile! But not for Ergodox :) I'm trying DIY dye-sub now and I want to test many profiles as possible.
I'm looking forward to GB.
Offline tbc
« Reply #11 on: Wed, 29 January 2014, 23:07:00 »
a normal set in black would be cool. cōmpletely disinterested in using high profile on an ergo board.
Offline mooswa
« Reply #12 on: Thu, 30 January 2014, 00:03:57 »
I am curious, is there an ergonomic problem with high profile?  Or something that interferes with ergodox specifically?
Offline tbc
« Reply #13 on: Thu, 30 January 2014, 00:29:15 »
i PERSONALLY for me think that making your fingers reach higher is unergonomic.  this applies to both standard and ergo boards; it's just mirw contradictory on a ergo board.
but no, SA caps work completely fine on the dox
