Author Topic: Just bought a Tipro on ebay and have a question.  (Read 3226 times)
Offline dunkin
« on: Mon, 06 January 2014, 20:18:05 »
Hello everyone! I am new here. I just purchased this item. A Tipro SHS-KM120BC-5W-001. I have downloaded the change me software and went digging for my long lost P/S2 cable. When I go into the software should I just use the MID-KM128-CM device?
I plan on using this with the chamsys lighting software. If all goes well I might look for one to use with some other audio applications. I am going to search for relegendable keys (mainly 2x2 and double shots). Does anyone have any good recommendations? Thanks for any help in advance!
Offline dunkin
Re: Just bought a Tipro on ebay and have a question.
« Reply #1 on: Mon, 06 January 2014, 20:38:32 »
Also, I have access to a "laser" (best Austin Power voice) at work.  Has anyone tried sanding the keys down and trying to laser engrave them?
Offline dunkin
« Reply #2 on: Sat, 11 January 2014, 10:09:57 »
An update...
I just received my tipro. A couple of notes:
It works great.
-The LCD mount is apart of the controller back panel. Probably going to hack it off unless someone has just the plastic piece.
-The places where there are 1x2 and 2x2 keys some of the switches have the springs removed. Does anyone know if the contact is still there? I might be able to just buy the springs.
-When I plug a keyboard into the controller (Daisy Chain) the keyboard doesn't work. There two other ports on the back but they have one of the pins blocked off so that I can't plug a normal P/S2 connector. When the unit is analyzed it shows a bar code reader. I assume that this is where that would get plugged in.
I am working on getting the characters for the software I am using. This going to be fun!
Offline dunkin
« Reply #3 on: Sun, 12 January 2014, 13:59:30 »
So I removed one of the switches without the springs. There are no contacts in the switch so even if I got springs they wouldn't work. So what I have decided to do is figure out my layout with the 2x2 and 1x2 keys and solder the stabilizing switches where I will need them.
Offline dunkin
« Reply #4 on: Sun, 12 January 2014, 19:25:56 »
Here is my work today. I am laying the boards out so that I can replace useable switches with support ones for the bigger keys. Taking the switches out isn't that bad with a solder sucker.
Offline dunkin
« Reply #5 on: Sun, 12 January 2014, 21:47:03 »
Getting there...now just need to find tipro keycaps in the U.S.
« Reply #6 on: Mon, 13 January 2014, 08:52:45 »
I think you can get relengendables from SP. I don't think they're in the Tipro profile though. Not 100% sure.
Offline dunkin
« Reply #7 on: Mon, 13 January 2014, 10:11:44 »
I was beginning to think I was talking to myself, lol! Do you know if anyone has gotten tipro to send keycaps to the U.S. other than through a proxy? I was going to try to roll the dice and see if they would mail me some. I know I would have to order min quantities but then I would have them to proxy to others. My other option might be x-keys also. I will compare them to sp. Thanks for the information. Now if only the software would operate like it is supposed too.
« Reply #8 on: Thu, 16 January 2014, 08:03:56 »
I don't really know actually. It's worth a shot to email them and ask though. And perhaps you can have a forum member help you proxy them. I think there's a couple guys from Slovenia here.
Offline dunkin
« Reply #9 on: Thu, 16 January 2014, 15:30:37 »
I did get a hold of someone. The problem mostly is the cost to ship. To ship a package of like .5lbs is ~$50. I might as well just buy the ones from SP. I ordered some keycaps from x-keys to see if they have the same profile. The package should be here tomorrow so we will see.
Offline dunkin
« Reply #10 on: Sat, 18 January 2014, 07:00:07 »
I received my keycaps from X-keys yesterday. The 2x2 are within the profile of the Tipro. The 2x1 and the 1x1 are not. They stick up ever so slightly. Also, I ordered a set of switches from them. I thought they were cherry blacks but to my surprise they are browns.
