Author Topic: Poker II Mod - PCB Mount?  (Read 2679 times)
Offline reziak
  • Topre/60% Enthusiast
« on: Tue, 07 January 2014, 03:24:46 »
Hey all, I'm doing my first real mod (new switches, LEDs, etc.) and I'm interested in doing a PCB-mounted board using a Poker II PCB. Will it work without the plate? Is there any reason why I shouldn't do that? I'm finding that I like the feel of PCB mounted switches for lighter switches - gives them a softer, more pleasurable feel. Thanks!
HHKB Pro 2 | FC660C | HHKB Pro 2 Type-S
Offline joneslee85
  • HHKB Scrub JP
  • Professional Rubyist programmer!
    • Ruby Journal
Re: Poker II Mod - PCB Mount?
« Reply #1 on: Tue, 07 January 2014, 05:15:35 »
I don't think there will be any problem. I hardly can tell the differences
TOO MANY KEYBOARDS THAT I COULD NOT COUNT! BUT I AM STILL USING MY MODEL F77
Offline reziak
« Reply #2 on: Tue, 07 January 2014, 07:52:17 »
I honestly didn't expect there to be a difference, but I just received a board with PCB-mounted reds, and it feels way different from my Poker 2 w/ reds. The Poker is very "pingy" and hard when you bottom out, while the new board has a very satisfying and softer bottoming out feel.
It's similar to the softness of the bottoming out on my HHKB, so I assumed the difference is in the plate vs PCB mount.
Offline BlueBär
« Reply #3 on: Wed, 08 January 2014, 05:27:30 »
The PCB has the holes for the PCB mount pins, so using PCB mount switches is not an issue. However I don't see any holes for PCB mount stabilisers - which you will need.
Offline reziak
« Reply #4 on: Wed, 08 January 2014, 11:12:57 »
Ah, good catch! Thanks!
