Author Topic: Filco USB to PS/2 Adapter spoilt, where can I get a replacement?  (Read 1419 times)
Offline wilflare
« on: Tue, 07 January 2014, 03:29:22 »
been using my Filco MJT1 Brown Switch (104keys) for a while now and I love it!
Unfortunately, my PC tower fell on its side and the PS/2 Adapter got bent ><
anyone knows where I can get a replacement? Hopefully, a filco one as well just for completion sake
Offline terran5992
  • One With The Cup Rubber
Re: Filco USB to PS/2 Adapter spoilt, where can I get a replacement?
« Reply #1 on: Tue, 07 January 2014, 03:35:39 »
Search on ebay.
There are tons of them
Offline stancato9
« Reply #2 on: Tue, 07 January 2014, 04:26:16 »
Try monoprice.com
Poker 2 - MX Red
Offline Grim Fandango
« Reply #3 on: Tue, 07 January 2014, 04:40:26 »
This should be easy to find. But someone can direct you to a specific place to buy them if you tell us your location. Which shops are available to you depends on whether you are in Europe, US or Asia.
If you are in the US, you can simply get them from newegg.com for something like 3-5 bucks.
Offline wilflare
« Reply #4 on: Tue, 07 January 2014, 05:09:38 »
thanks! I'm in Asia, specifically Singapore
