Author Topic: Several questions about the 122 Key Model M  (Read 2941 times)
Offline ibell7945
« on: Tue, 07 January 2014, 07:55:34 »
Now that I've made the plunge into mechanical keyboards by purchasing a Model M (part number 1394100, 122 key with RJ-45 terminal connector). Though I've read Soarer's thread and ordered a teensy, I'm currently attempting to disassemble the keyboard for a more thorough cleaning. On the back, I attempted to take the three bolts/screws off, but found they seemed to be a nonstandard size. Does anyone know the size of these screws? Also, will modern Unicomp replacement keycaps work with this board?
IBM 122 Key Model M
Offline Aer Fixus
  • And now, back to lurking...
Re: Several questions about the 122 Key Model M
« Reply #1 on: Tue, 07 January 2014, 09:28:43 »
Same size as a Model M.
5.5mm or 7/32' bolt driver.
And, yes. Unicomp caps will fit. Most buckling spring caps will work on your board, so you can swap with a Model M or a Model F if you wish. The exception is the Model M2 and some other obscure boards.
               SOON: IN PROGRESS:
I lie all the time.... I really don't even like keyboards
Offline ibell7945
« Reply #2 on: Tue, 07 January 2014, 09:38:00 »
Thanks for the bolt size, as I'm going to the hardware store today to pickup a driver. However, another question occurred to me. Considering this is a terminal keyboard, will the mods that work with this model be more similar to the mods that work with the Model F terminal keyboard or other Model M keyboards?
IBM 122 Key Model M
« Reply #3 on: Tue, 07 January 2014, 10:16:05 »
The hardware store is not likely to have the "long" or "thin-walled" 7/32" socket you need (5.5mm will substitute well) so you might try an auto parts store. Here is a good cheap item if you are willing to wait a few days, I bought one:
http://www.ebay.com/itm/Allen-30803-SAE-Nutdriver-Soild-Shaft-7-32-USA-/390441743902?pt=US_Srewdrivers_Nut_Drivers&hash=item5ae824361e
Otherwise the mechanical work is the same as any other Model M and Soarer's Converter with Teensy will work just fine.
Here are the bolts you need, and you won't find them at the hardware store, either. The self-tappers at the bottom are unnecessary.
- D Trump 2026-10-24
« Reply #4 on: Tue, 07 January 2014, 10:17:17 »
double post, sorry
Offline ibell7945
« Reply #5 on: Tue, 07 January 2014, 12:15:47 »
Thanks for the recommendations and links. On an unrelated note, I originally wanted one of these keyboards because I saw your posts on modifying them.
IBM 122 Key Model M
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #6 on: Tue, 07 January 2014, 12:43:56 »
i got my deep, thin walled 7/32 socket at lowe's if i am not mistaken for what its worth
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline berserkfan
« Reply #7 on: Wed, 08 January 2014, 05:41:32 »
All you really need, apart from the nut driver, is a teensy with pins and some dupont connector cables.
you can always remove the obsolete telephone style cable and put in the dupont connector cables which you connect to your teensy. that way you don't need to build a female adapter for the telephone cable.
