Author Topic: Unicomp Customizer 105 layout  (Read 3977 times)
Offline Chloe
  • Switch Kitten
« on: Wed, 11 February 2009, 18:30:31 »
Does anyone know what type of Enter key this model has? I've only seen 104 key with horizontal Enter and backslash above it.
Offline dw_junon
    • http://www.9999hp.net/
« Reply #1 on: Wed, 11 February 2009, 19:41:56 »
I'm quite sure that it's the upside-down inverted L as found on the 102 Customiser, the 1391406s, and just about everything else...  Of course, I can't remember where I last saw one now, and can't [well, not easily] find a picture.
ARC/Chicony KB-5181 XT/AT blue ALPS? 101 US FCC ID E8H51KKB-5181 • AST ASTKB102 AT capacitive rubber dome 102 UK ISO
Cherry G80-2100 AT black Cherry 126 key German ISO unique • Compaq Enhanced III PS/2 unknown rubber dome 102 UK ISO
Datacomp DFK102ARA03 AT 102 blue ALPS? US/Arabic FCC ID blank, S/N 37880001 • Dell AT102W PS/2 Black ALPS 105 UK ISO x2
Fujitsu KFB4725-102 AT membrane rubber dome with spring 105 UK ISO • Hewlett Packard C1405A AT rubber dome 102 UK ISO
IBM 0989705 XT/AT no LEDs Model M 102 US/Arabic  • IBM 1388076 Industrial AT Model M 102 UK ISO
IBM 1389260 3179/3180 Display Station Model M 122 US 3270 x2 • IBM 1391406 PS/2 Model M 102 UK ISO x2
IBM 1397003 PS/2 Model M "Host Connect" emulator 122 German ISO • IBM 71G4643 PS/2 Model M Quiet Touch "Ouch!    Rubber spring" 102 UK ISO x2
IBM 5640987 3178 Display Station Model C2 capacitive buckling spring 87 key US 3270 • IBM 556-712-01 RT PC rubber dome [same as 2nd PCjr kbd?] 101 US
IBM 6450225 PC/AT capacitive buckling spring 84 key UK PC/AT • Lexmark 8125460 Model M2 102 UK ISO
NMB RT-102 117456-002 AT Hi-Tek black, clicky 102 UK ISO • Olivetti ANK 2462 M24 Personal Computer keyboard 2 clicky Olivetti spring module 102 UK unique
Ortek MCK-142Pro AT white ALPS 142 key UK • Sun 540-1006-03 Type unknown linear(?) keyswitch 2 87 key SunType2
Wang 724 725-3771-UK salmon ALPS 110 key UK Wang724 • Making this list hasn\'t half scared me...
[/I]
Offline dw_junon
[/I]
Offline Chloe
  • Switch Kitten
« Reply #4 on: Wed, 11 February 2009, 20:27:59 »
Thanks. :)
Offline ch_123
« Reply #5 on: Fri, 13 February 2009, 09:12:10 »
Here's my Endurapro with 105-key layout http://img297.imageshack.us/img297/3963/endurapro105pt0.jpg
Offline bhtooefr
    • bhtooefr.org
« Reply #6 on: Fri, 13 February 2009, 09:13:45 »
Does anyone else see the problem with that setup? :p
(Let's see. PS/2 EnduraPro, into a PS/2 to USB converter, with a USB to PS/2 pin converter for a mouse.)
Offline ch_123
« Reply #7 on: Fri, 13 February 2009, 10:48:27 »
Heh, I took that picture after I checked to see if the above configuration would work, just to save USB ports. However, the Endurapro's PS/2 passthrough doesnt seem to like scroll-wheels.
Offline dw_junon
« Reply #8 on: Fri, 13 February 2009, 11:19:30 »
Quote from: bhtooefr;21643
It's perfect.  You can stick the converter's plug into the keyboard when the EnduraPro isn't in use.  That's a tidy bit of design there.
[/I]
