Author Topic: Silicon Graphics Granite (AT-101) $54 shipped & interesting old Ketronic  (Read 2426 times)
« Last Edit: Sun, 12 January 2014, 02:12:23 by nubbinator »
Offline blueSmoke
  • Life is what happens while you're busy Fixing RSI
Re: Silicon Graphics Granite (AT-101) $54 shipped & interesting old Ketronic
« Reply #1 on: Sun, 12 January 2014, 02:22:59 »
I believe the first two are alps sliders and the last two are capacitive foil ones. These have a slider with a spring at top and foam+foil at bottom. not that great...
Model M, Filco Tenkeyless White, Few others, few more others, Noise-hater (ongoing project), blah-blah (to be fillled later...)
« Reply #2 on: Sun, 12 January 2014, 02:28:55 »
I know for a fact that the first two are Alps, likely Cream Alps.  The next two, after closer inspection, probably are foam over foil.
Offline AKIMbO
  • HHKBro
The sgi boards are dampened cream alps. They look to be in great shape too. It's a shame about that cable.
| KBD75 (box reds)
Offline dante
« Reply #4 on: Sun, 12 January 2014, 10:18:30 »
Despite foam over foil the keycaps have more sex appeal than 99% of the mass produced crap shoveled today.
« Reply #5 on: Sun, 12 January 2014, 13:59:10 »
http://www.ebay.com/itm/NEW-OLD-STOCK-KETRONICS-COMPUTER-KEYBOARD-VINTAGE-/261372733041?pt=PCA_Mice_Trackballs&hash=item3cdb076671
http://www.ebay.com/itm/KETRONICS-COMPUTER-KEYBOARD-VINTAGE-/251423103202?pt=PCA_Mice_Trackballs&hash=item3a89fc18e2
I'm guessing it's an old Hall Effect switch.
Highly doubt it: I have never seen a hall effect keytronic KB. Keytronic did make some reed switch keyboards back in the day (I have tried several). The cheapest reed switches you can get are old gilbarco panels that use them.
These two are both clearly capacitive. You can see the capacitive pads under each switch through the bottom of the PCB.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #6 on: Sun, 12 January 2014, 22:57:04 »
I'd warrant the SGI caps make a good swap for, say, an AT101W's ugly lasered caps... except for the bottom row :/
Overton130, Box Pale Blues.
« Reply #7 on: Mon, 13 January 2014, 00:19:04 »
Why don't you use the SGI keyboard as it is? It talks PS/2. It has Cream Alps which many find to be much nicer than the Black Alps of the Dell AT101W.
If you don't like the granite case, chances are that the innards fit inside a Dell AT101.
Anyway, the "SGI Granite" is a bit of a collector's item and worth more complete.
