Author Topic: Gonna lube mah HHKB  (Read 2592 times)
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
Gonna lube mah HHKB
« on: Mon, 13 January 2014, 07:23:44 »
Gonna lube my HHKB and do the dental band mod to quell the reset noise (resonates through my desk and amplifies it).
All I want to know is, any advice on lube locations for the switches?
Offline yasuo
  • spanengan puyeng newbie
Re: Gonna lube mah HHKB
« Reply #1 on: Mon, 13 January 2014, 07:27:06 »
Logitech MK220 Colemak DH
« Reply #2 on: Mon, 13 January 2014, 07:27:12 »
I did mine like the following
http://geekhack.org/index.php?topic=51181.msg1145306#msg1145306
^^ there's also more info around that post as well
also this is an idea
http://geekhack.org/index.php?topic=52606.msg1168258#msg1168258
Offline pexon
    • Pexon PCs
« Reply #3 on: Mon, 13 January 2014, 08:08:59 »
Brilliant, just what I was looking for.
Thanks chaps
« Reply #4 on: Mon, 13 January 2014, 12:45:26 »
Hey originative is still sold out of thick can I use the thin on my HHKB?
« Reply #5 on: Mon, 13 January 2014, 12:49:38 »
I thought they restocked? Might PM mkawa he might have some.
« Reply #6 on: Mon, 13 January 2014, 12:51:18 »
Thanks Ray!
