Author Topic: Can anyone recommend me a good numpad?  (Read 3724 times)
Offline kskwerl
« on: Mon, 13 January 2014, 17:33:38 »
The Realforces are hard to find and too expensive as I just got the HHKB Pro 2
HHKB Pro 2 - Leopold 210TP -
Offline neunelfer
  • HHKB Pro
Re: Can anyone recommend me a good numpad?
« Reply #1 on: Mon, 13 January 2014, 17:36:37 »
I have a Filco numpad with browns that I got used on eBay for about $35. Elitekeyboards sells Leopold numpads for $45 plus shipping. Be aware though that many people have reported that the keys on it send the same scan codes as the number row of a keyboard. This shouldn't really be a problem though unless you were planning on binding macros to the keys.
Offline kskwerl
« Reply #2 on: Mon, 13 January 2014, 17:54:58 »
I'd like a white one to match my HHKB Pro 2 if possible. I'll just be using it for entering phone numbers and credit card info.
Offline fourzeropooh
« Reply #3 on: Mon, 13 January 2014, 17:55:53 »
Qtan sells white numpads
Offline kskwerl
« Reply #5 on: Tue, 14 January 2014, 03:14:20 »
Who's Qtan? Also are these any good? http://www.amazon.com/dp/B000KIXIAQ/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=16O8JDCR6NULD&coliid=I3617FMD3WI2Z9
« Reply #6 on: Tue, 14 January 2014, 03:47:10 »
http://www.vendio.com/stores/E-sports-Gaming-equipments/item/shop-mechanical-keyboard-by-br/leopold-210tp-mechanical-keypa/lid=36753673
He also has a vendor forum on GH.
« Reply #7 on: Tue, 14 January 2014, 03:51:14 »
Get the white Leopold! I love my black one.
Offline kskwerl
« Reply #8 on: Tue, 14 January 2014, 04:44:33 »
« Last Edit: Tue, 14 January 2014, 04:46:47 by kskwerl »
Offline kskwerl
« Reply #9 on: Tue, 14 January 2014, 04:46:05 »
This is exactly what im looking for thanks!
