Author Topic: Keycap font  (Read 3713 times)
Offline Euf0ria
Keycap font
« on: Tue, 14 January 2014, 03:25:39 »
Hi guys!
I need help to figure out the the name of the font used on this keycap-set:
http://www.ebay.com/itm/104PBT-white-printed-keycaps-for-Keyboard-Filco-Cherry-/300910270965?pt=LH_DefaultDomain_0&hash=item460fa659f5
The reason for my question is because i have ordered this keycap-set and since it´s ANSI layout and i use ISO i will fix blank keycaps and print the missing symbols by myself (technique to use not decided yet).
Also, if someone have printed their own keycap symbols/legends earlier I would love to hear how you did it!
All your base are belong to us
Offline terran5992
  • One With The Cup Rubber
Re: Keycap font
« Reply #1 on: Tue, 14 January 2014, 06:37:38 »
Seems like something that Coolermaster used
Offline Euf0ria
Re: Keycap font
« Reply #2 on: Tue, 14 January 2014, 06:49:29 »
Yes it really looks to be the same or at least similar enough. So what is it called?  :eek:
Offline tooki
Re: Keycap font
« Reply #3 on: Tue, 14 January 2014, 08:58:04 »
It's called Bank Gothic. https://en.wikipedia.org/wiki/Bank_Gothic
For the future: if you have a clean sample of a font, you can use WhatTheFont to identify it. It's amazingly accurate.
Re: Keycap font
« Reply #4 on: Tue, 14 January 2014, 09:00:18 »
Check this out.
Offline Euf0ria
Re: Keycap font
« Reply #5 on: Tue, 14 January 2014, 09:44:41 »
Thats brilliant, thank you guys so much for the quick help! I just love this kind of combined knowledge.
Now i only have to find a simple and sustainable method to get it on there. The link above is kind of awesome but i think that there must be a more simple solution in my case since I´m going for side printed and will have close to zero wear on that surface.
Offline Wildcard
  • When caffeine isn't enough
Re: Keycap font
« Reply #6 on: Tue, 14 January 2014, 14:52:52 »
We're like Google but without the free lunches.
