Author Topic: PBT Rainbow filco!  (Read 3830 times)
Offline n0rdlad
PBT Rainbow filco!
« on: Tue, 14 January 2014, 05:28:09 »
Look at my PBT Rainbow Filco.
She's O-ringed up an the sound and feel is amazing.
So stoked!
- Filco MJ2 104 MX Brown -
Offline Vaii
  • wat
Re: PBT Rainbow filco!
« Reply #1 on: Tue, 14 January 2014, 06:44:30 »
That does look really good, are they thick pbt caps?
wtb dark plushberry (mx) bbv2 / starcluster (mx) bbv2
Offline n0rdlad
« Reply #2 on: Wed, 15 January 2014, 20:27:55 »
No. Just the thinner kind. Still thicker than the stock caps :)
Offline BakerMan1971
« Reply #3 on: Thu, 16 January 2014, 08:10:49 »
Got a pal with the Keycool variation that came with rainbow caps, the only problem is they look like candy and definitely very tasty in appearance, ...... must not eat.... must not eat :)
Offline n0rdlad
« Reply #4 on: Sat, 18 January 2014, 03:03:25 »
Totally! Haha the pastel colours make them reminisant of pez or musk lollies.. :) I wonder if they'de glow  on a ducky shine..?
Offline epzy
  • HHKB Fiend
  • ded
« Reply #5 on: Sat, 18 January 2014, 04:07:51 »
Woops.  :blank:
« Last Edit: Sat, 18 January 2014, 04:11:58 by epzy »
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6 on: Sat, 18 January 2014, 04:11:10 »
They would. I think only double-shot PBT wont shine through.
Offline RESPRiT
  • HHKB = ❤
« Reply #7 on: Sat, 18 January 2014, 07:47:03 »
Where'd you pick these up? For some reason all the rainbow caps I've seen are sideprinted and ABS.
Offline Mikey Mo
« Reply #8 on: Sat, 18 January 2014, 10:57:12 »
very nice
« Reply #9 on: Mon, 20 January 2014, 04:35:51 »
Hi n0rdlad
I tried some of my friends caps on my Keycool 87II which has purpble lighting, and yes you get light through although it's uneven and the stem and strengthening bits are darker, often looks like the back half of the switch is brighter, not bad looking but not designed for backlighting.
Hope this helps, if you need a picture I still have his Red ESC on my board so will take one when I get home :)
Offline n0rdlad
« Reply #10 on: Thu, 23 January 2014, 06:09:15 »
 http://m.aliexpress.com/item/900696469.html?tracelog=storedetail2mobilesitedetail
Offline n0rdlad
« Reply #11 on: Thu, 23 January 2014, 06:14:11 »
Hi n0rdlad
Cool thanx mate. I'll post a vid that gave me the idea.
Offline n0rdlad
« Reply #12 on: Thu, 23 January 2014, 06:19:52 »
feature=youtube_gdata_player
 :cool:
« Reply #13 on: Thu, 23 January 2014, 09:41:18 »
Thanks for the video, yes that turned out as expected, there are thicker areas on the PBT's that don't let light through.
It does look incredibly cool.
