Author Topic: Which ****ing ps2-usb adapter will work?  (Read 6002 times)
Offline schmolch
« on: Fri, 13 February 2009, 08:15:59 »
I have 2 Model M's with german layout and the key right of the left shift key does not register.
First i bought this usb-adapter:
http://i3.ebayimg.com/01/i/000/ff/03/d65a_1.JPG
And after i read about the issue here i bought this one which was recommended as working:
http://i10.ebayimg.com/04/i/001/2f/12/d6de_1.JPG
None of them works, on none of my M's, on none of my Computers.
So please, can anybody tell me which ****ing Adapter i need to buy?
Sorry for the swearing.
Offline bhtooefr
    • bhtooefr.org
« Reply #1 on: Fri, 13 February 2009, 08:21:42 »
First off, are you sure that key is working when you connect it to PS/2?
If it is... then I dunno.
Offline schmolch
« Reply #2 on: Fri, 13 February 2009, 08:23:51 »
I dont have ps/2 and i cant get it (Laptops).
Offline bhtooefr
    • bhtooefr.org
« Reply #3 on: Fri, 13 February 2009, 08:26:01 »
Got any friends with a computer with a PS/2 port? I've got an old desktop that does three things:
1. Serves web pages and files
2. Runs irssi
3. Has PS/2 ports, for testing keyboards and such
Offline schmolch
« Reply #4 on: Fri, 13 February 2009, 08:33:23 »
Another thing, isn't ps/2 hot-pluggable?
When i disconnect the adapters they wont work again until i reboot.
This is driving me insane.
Offline bhtooefr
    • bhtooefr.org
« Reply #5 on: Fri, 13 February 2009, 08:35:17 »
PS/2 is a weird beast. It's not hotpluggable under Windows, but is under Linux.
But, that's irrelevant - USB IS hotpluggable, and the adapters I've used... worst case is that I'd have to unplug it and plug it back in when disconnecting or connecting a PS/2 device.
Offline lowpoly
« Reply #6 on: Fri, 13 February 2009, 08:40:55 »
Using my ps/2 to usb converter:
unplugged/re-plugged:
Looks like it works. Let's see if I can find it on ebay...
This one:
http://cgi.ebay.de/USB-PS-2-Konverter-aktiv-2x-PS-2-Adapter-an-USB-Port_W0QQitemZ370157709028QQcmdZViewItemQQptZDE_Technik_Computerzubeh%C3%B6r_Kabel_Adapter?hash=item370157709028&_trksid=p3286.c0.m14&_trkparms=72%3A1229|66%3A2|65%3A12|39%3A1|240%3A1318
But I think the adapter does a simple signal conversion. This should not affect a single key. The reason for the key not working must be elsewhere, IMO.
Offline schmolch
« Reply #7 on: Fri, 13 February 2009, 08:42:09 »
Im using Linux but i just noticed that the vivanco adapter i got is not the same model as the one that was recommended.
So im gonna get the right one now.
Offline schmolch
« Reply #8 on: Fri, 13 February 2009, 08:45:33 »
Thanks lowpoly, i ordered one of those.
Offline bhtooefr
    • bhtooefr.org
« Reply #9 on: Fri, 13 February 2009, 09:01:37 »
Quote from: lowpoly
Unless the USB converter isn't passing the scancodes straight through, and only passes the scancodes that a standard US 104-key keyboard can generate...
Offline xyzzy
« Reply #10 on: Fri, 13 February 2009, 09:04:08 »
I had the same problem with a PS/2 to USB adapter that looks like your first one, as reported here: http://geekhack.org/showthread.php?t=1076&page=2#post13473
It looks like some adapters just won't work with the 105th key found in ISO layout (the one to the right of left shift) and they'll only "see" the 104 keys in ANSI keyboards.
IBM Model F62 (Ellipse's) • PFU HHKB Pro Type S Hybrid • PFU HHKB Pro • Leopold FC660C • IBM Model M SSK 1391472 • IBM Model M SSK UNI04C6 • IBM Model M 1391405 (x4) • Cherry MX 1800 Compact (blue Cherry) • Cherry MX 11900 Touchboard (brown Cherry) • Dell AT102W (black Alps) • Apple Extended Keyboard II (cream Alps) • Acer 6312-TA (black Acer) • Unikey KWD-601 (white Cherry)
Offline CX23882
« Reply #11 on: Fri, 13 February 2009, 09:05:34 »
The issue that I've seen with some PS/2-USB adapters is with 102/105 key UK layouts, where the \ | key isn't sent.  This is a huge issue if for example you need to access network shares.
Offline sandy55
« Reply #12 on: Sat, 14 February 2009, 01:40:11 »
Two among three of my PS2->USB adapters fail to send the key ( at the right of left Shift key).
Offline wheel83
« Reply #13 on: Mon, 16 February 2009, 20:20:36 »
is there any tests that most adapters display any input lag ??
I <3 BS
