Author Topic: IBM Model M: PS/2 vs AT cable  (Read 2601 times)
Offline ozar
« on: Sat, 14 February 2009, 10:02:51 »
Would any of you happen to know if a Model M that came with the black cable and AT type connector will work if I remove that cable and plug in the cable that comes with the PS/2 connector?  Or is it a must that I use the default black cable and use an AT to PS/2 adapter with it?
I'm guessing that substituting the cable should work fine, but don't want to break anything by not asking before doing it.
Thanks to anyone that knows for sure!
Offline sandy55
« Reply #1 on: Sat, 14 February 2009, 10:14:44 »
It does.
for example, 1390120 and 1390131 both work fine with a ps/2 plug cable.
Offline ozar
« Reply #2 on: Sat, 14 February 2009, 10:27:22 »
Ok, that's what I thought... thanks for the help, sandy!  :cool:
Offline Mercen_505
« Reply #3 on: Sat, 14 February 2009, 11:42:49 »
Thanks, Sandy. I've been wondering about that myself.
