Author Topic: upgrading a WASD v2  (Read 2034 times)
Offline CalmB4tehPwn
  • Demon of the Fall
upgrading a WASD v2
« on: Wed, 15 January 2014, 14:44:38 »
So a couple weeks back, my micro-USB port on the back of my v2 broke right off it's (what's the term for that? Break-out board?) mini PCB. So I contacted WASD and they promptly sent out a replacement and a tool to help open the case.
As soon as I saw the replacement part, and that it was a filco connection, I realized I had a filco terminated custom cable laying around. So I took my dremel and opened the port up a bit, so the hole in the case was big enough to fit a cable through. I plugged it in and everything was coming up green, but I have a question.
The v2's controller looks exactly like the QFR controller, and I have a frosty flake on hand that's not going to any good use. Do you think it'd be possible to use the frosty flake? And with the v2, would there be any point?
"I seek a great warrior" - Luke Skywalker
"Great Warrior, Hmm? War does not make one great." - Master Jedi Yoda
Re: upgrading a WASD v2
« Reply #1 on: Wed, 15 January 2014, 15:01:23 »
I would consult the creator of the frosty flake for his input.
Offline joneslee85
  • HHKB Scrub JP
  • Professional Rubyist programmer!
    • Ruby Journal
« Reply #2 on: Wed, 15 January 2014, 15:19:26 »
I think not, due to the fact each board will have different resistors for their LEDs, you should ask the author
TOO MANY KEYBOARDS THAT I COULD NOT COUNT! BUT I AM STILL USING MY MODEL F77
