Author Topic: [IC] Simple modifier set  (Read 10560 times)
Offline jonathanyu
« on: Thu, 16 January 2014, 01:38:05 »
Just a interest check
Basically are the modifier keys that on G80-1501 HAD except ctrl/alt, but in standard ANSI layout
pic from google
Anyone are interested in this?
« Last Edit: Thu, 16 January 2014, 01:55:34 by jonathanyu »
Offline ebacho
Re: [IC] Simple modifier set
« Reply #1 on: Thu, 16 January 2014, 02:00:45 »
Assuming GMK, I'd be in.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #2 on: Thu, 16 January 2014, 02:09:59 »
If it is GMK I seriously doubt it will get the traction to hit MOQ, all GMK GB's have been struggling lately and considering these were available at Originative for quite a while I don't think you'll get many takers.
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #3 on: Thu, 16 January 2014, 06:56:12 »
ANSI layout ? Really?? Very interested :) I hope you can run GB  :thumb:
Offline damorgue
    • Personal portfolio
« Reply #4 on: Thu, 16 January 2014, 06:58:49 »
One of few GMK Bs which I honestly believe could meet MOQ is a proper moogle and mod set.
Offline tjweir
« Reply #5 on: Thu, 16 January 2014, 07:25:59 »
Interested.
Offline ideus
  • Björkö.
« Reply #6 on: Thu, 16 January 2014, 07:55:01 »
In for a GMK moogle if it includes also 1x mods besides 1.25x.
Offline ideus
  • Björkö.
« Reply #8 on: Thu, 16 January 2014, 08:06:09 »
http://geekhack.org/index.php?topic=52035.msg1150927#msg1150927
What I loved about that interest check was this:
"6,25x/7x spacebra."
So now we should check if that bra is larger than a DD
:D
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #9 on: Thu, 16 January 2014, 13:36:28 »
This is certainly on my to do list, black on beige MOD+ set that is... if someone wants to take it before I get to it please be my guest.
Offline ideus
  • Björkö.
« Reply #10 on: Thu, 16 January 2014, 14:00:40 »
And now with the reduced MOQ may certainly happen. Thanks again Ivan.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #11 on: Thu, 16 January 2014, 14:10:02 »
Get the windowed keys in the mod pack = WIN
-Enzo Ferrari
Offline ideus
  • Björkö.
« Reply #12 on: Thu, 16 January 2014, 14:32:06 »
As far as I know a GB for a GMK made moogle or tsangan has never been intended. If regular colors like beige and black are included I do not see any reason for many not to get on board as now they may be using SP made equivalents that are just not similar to GMK. Also Originative does not sell modifier sets but full ones. So there is not much reason for no-go comments in here.
Offline daetsid
« Reply #13 on: Thu, 16 January 2014, 15:14:11 »
give me GMK mod sets NOW!
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #14 on: Thu, 16 January 2014, 19:56:32 »
would be interested if windowed
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
« Reply #15 on: Thu, 16 January 2014, 21:51:26 »
I could be interested in this.
Offline Dubsgalore
« Reply #16 on: Thu, 16 January 2014, 22:27:20 »
much interest here
Offline bazh
« Reply #17 on: Thu, 16 January 2014, 22:28:58 »
I'm in :D
HHKB Pro2 white
Newbie again
Offline LechnerDE
« Reply #18 on: Fri, 17 January 2014, 04:17:57 »
With the new MOQ of 250 this seems doable. I am really looking forward to all the GMK GBs 2014 will bring :)
Offline bazh
« Reply #19 on: Fri, 17 January 2014, 04:24:52 »
but dem windowed keycaps still need 400 :(
HHKB Pro2 white
Newbie again
Offline LechnerDE
« Reply #20 on: Fri, 17 January 2014, 04:35:28 »
Windowed caps could just be doubled per set so we indirectly reach the MOQ for them.
  • Frenzy Classic.
« Reply #21 on: Fri, 17 January 2014, 07:35:15 »
This is certainly on my to do list, black on beige MOD+ set that is... if someoe wants to take it before I get to it please be my guest.
you just do mod set or both base & mod
« Reply #22 on: Fri, 17 January 2014, 14:33:43 »
Assuming I'm the one running it, when beige is done I will do all the keys that would typically be beige on a set and offer that all as one pack. The reason is Cherry used a lot different shades of beige/light grey on 2tone sets. GMK only have a few shades in that color family... and none of them really match 100% let alone to match all the possible shade variations you might have. It will make it a much more difficult/larger and more expensive set than for example white/black where you could get away with only the most needed keys instead since black color variance would be very minimal.
Offline LechnerDE
« Reply #23 on: Sat, 18 January 2014, 02:27:24 »
Seems reasonable. On top of that everybody will probably have a different shade of beige due to yellowing, so it's definitely the best to make a complete Mod set instead of just a couple of keys.
Offline jonathanyu
« Reply #24 on: Sat, 18 January 2014, 02:49:10 »
maybe also include esc, F4-F8, etc.  but they would probably bring up the price
Offline LechnerDE
« Reply #25 on: Sat, 18 January 2014, 03:55:51 »
Well F4-F8 and the Nav Keys are part of the Mod set. Doesn't a standard Mod set look like this?
I am not really interested in this if the above shown keys are not in it.
« Reply #26 on: Sat, 18 January 2014, 14:16:44 »
Basically this with some tweaking, in black/beige... all as one thing.
Perhaps will just do black/beige and white/black with identical configurations at same time and just make it simple and fulfill needs for 'classic' adapter packs.
« Last Edit: Sat, 18 January 2014, 14:23:28 by IvanIvanovich »
« Reply #27 on: Sat, 18 January 2014, 15:50:39 »
Would be super awesome to be able to get some ANSI ('caps lock' text instead of the arrow, etc) windowed lock keys.
I would buy 5-10 sets of the windowed locks alone if needed to get closer to the MOQ. Probably 2 sets of modifiers if the windowed locks were included.
Offline Dubsgalore
« Reply #28 on: Sat, 18 January 2014, 15:54:49 »
If there was a windowed caps lock in ansi legends, i would commit to ordering 10-20 of them to helping hit moq
ivan's point about the ridiculous amount of beige out there makes you worry...
« Reply #29 on: Sat, 18 January 2014, 15:55:39 »
Pick the beige that's closest to BSP sets. GMK windowed locks + BSP set = win
Offline ideus
  • Björkö.
« Reply #30 on: Sat, 18 January 2014, 16:31:50 »
A quotation may come handy to pull interested people into the interest check -> group buy.
« Reply #31 on: Sat, 18 January 2014, 18:03:33 »
GMK has been really slow getting back to me about some things. I already put in for some quotes on a revision of the white/black some time ago... generally stock colors don't make difference to pricing. Even though I don't have final quote I will guess it will cost something like $75.
Offline ideus
  • Björkö.
« Reply #32 on: Sat, 18 January 2014, 18:06:32 »
That's a good start. Are you going to offer the WoB also?
  • Frenzy Classic.
« Reply #33 on: Sun, 19 January 2014, 10:50:39 »
I still wait it everyday :). I 'll do anything i can to hit MOQ :)
Offline damorgue
« Reply #34 on: Mon, 20 January 2014, 04:13:33 »
I really would like the text legends too in general. Although the intention with symbols was to make them work in mourse layouts/countries, I would say that the opposite is true and there are more different symbols than there are text strings for the different caps.
Offline tinlong117
« Reply #35 on: Mon, 20 January 2014, 06:48:44 »
ok, i already dropped a message to gmk.
