Author Topic: Ducky Zero 2108 or 2108S?  (Read 1984 times)
Offline iamlawrencev
« on: Thu, 16 January 2014, 08:47:29 »
Hi guys I just wanted to ask which should I choose, the DK2108 or DK2108S? It seems the only major difference is the backlight which I probably won't be using anyways. I'm only concerned about the keycaps on the DK2108. Does it fade away with use? Should I save more and buy the DK2108S since people say that the keycaps on those don't fade away because it's backlit?
I can't stand keycaps fading away, I wish they would've made them blank if they would just fade away so easily. Thanks guys :)
