Author Topic: RK9000 usb port broke; need tips on soldering :<  (Read 1976 times)
Offline evanui
« on: Thu, 16 January 2014, 10:51:31 »
After jumping head first into trying to repair the thing myself, I have ended up stuck with two questions.
I have cut and stripped one of the cables that came with the keyboard; the PS/2 to mini USB. And I've looked up the pinouts for said USB and they're to be in the order: red - white - green - ? - black. Which leaves me slightly confused because the usb cable only splits into the four colors red white green and black. The tiny USB port that I've removed also had a wire in all five connections. Is there something I need to do with the last connection? Or will I simply leave one connection empty?
Finally, and most importantly, which 'direction' should the pinout be arranged on those five connectors? Tracing the wires from the mini USB port I removed, it would either be from left-to-right or right-to-left in a straight forward fashion.
This is a relevant image, though not of my own:
http://justbrewit.net/trstuff/RK-9000/connector2.jpg
Please refer to said image to keep our lefts/rights/ups/downs on the same page!
