Author Topic: Deciding between Filco MJ2 and Ducky Zero  (Read 4231 times)
Offline Xest
« on: Fri, 17 January 2014, 00:37:09 »
Hello, recently my CM QFR (red) died on me so i'm looking for another keyboard. I don't need backlight so I have narrowed my choices down to the Filco MJ2 and Ducky Zero. They are both in a similar price range shipped (110-120AUD), so i'm wondering what are your opinions. Generally I have heard Filco's are good overall but some say the Ducky is actually better so i'm just having some trouble deciding. I will be trying out MX browns this time :P
Offline CatNip :3
  • bouncy bouncy
Re: Deciding between Filco MJ2 and Ducky Zero
« Reply #1 on: Fri, 17 January 2014, 01:00:58 »
I would say the Filco Majestouch 2. The Ducky Zero is more of a budget line that Ducky makes, unlike the Shine and G2 Pro series. :)
Offline fuzzybaffy
« Reply #2 on: Fri, 17 January 2014, 01:29:57 »
Well... I have no idea how helpful this would be, since I don't have Ducky Zero... But I just got my Filco MJ2, and it's quite nice. It is much better than the other Cherry MX board I had, which I believe was based on one of the Keycool boards.
« Reply #3 on: Fri, 17 January 2014, 02:32:40 »
Quoting AUD, you in Australia?
Where can you get Filco for max $120?
Also, Filco is generally considered better, but is also generally much more expensive than Ducky Zero.
Offline Tony
« Reply #4 on: Fri, 17 January 2014, 02:37:22 »
I have tried both and Filco is a bit better in typing feel and better built. Though that tiny bits cannot justify the price difference, I still bought the Filco and never regret it.
EDIT: If you find them at the same price, then Filco definitely.
Offline Xest
« Reply #5 on: Fri, 17 January 2014, 03:00:15 »
Thanks for the replies, but in general the Ducky Zero is still pretty decent compared to the Filco am i right?
Offline kfmfe04
« Reply #6 on: Fri, 17 January 2014, 03:11:10 »
Not really.
The general consensus is, Filco has a higher quality build than Ducky.  In the last few years, Ducky has been catching up, but if you put a MJ2 and a Shine 3 next to each other, most people would agree that the Filco feels more solid.  Usually, the choice comes down to features (if you want backlit, get the Ducky) or price (Ducky is cheaper).
The Zero is built in China (whereas the Shine 3 is built in Taiwan) and is considered to be a notch down (and cheaper still) compared to the Shine 3.
IIRC, the Zero isn't even backlit - if that's the case and the prices are similar (as a post mentioned earlier, the prices you listed look suspect, especially for the MJ2), I can't come up with a reason to buy a Zero over a MJ2.
⌨White Blank HHKB P2 ⌨Filco TKL SA MXRed
Interests: ⌨AcidFire's Board ⌨Kinesis Advantage LF
Offline Oobly
« Reply #7 on: Fri, 17 January 2014, 03:40:52 »
At a similar price shipped, the Filco will be the better board. Really solid.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #8 on: Fri, 17 January 2014, 04:02:15 »
I have two Ducky Shine (version 1).  Both are great boards, both still going strong after a year of use - one gets daily use at work.
But yes, for the same money, a Filco would give you that little bit extra quality.
That is why it is surprising to find a Ducky Zero and Filco priced about the same - usually Filco is about $170 and Ducky Zero is $95 (in Australia, anyway).
Offline Xest
« Reply #9 on: Fri, 17 January 2014, 05:06:04 »
The Filco is used abit by my friend so he is selling it cheaper to me, forgot to tell you guys haha
Offline Tony
« Reply #10 on: Fri, 17 January 2014, 05:12:11 »
Then you should get the Filco. Say thanks to your friend. Be good and good things happen to you.
Offline Proc31
« Reply #11 on: Fri, 17 January 2014, 06:16:03 »
For that price it would be wrong not to get to get the Filco, the only real drawback of the boards in my opinion are the price but considering you are getting it on the cheap it would be crazy not to get it.
« Reply #12 on: Fri, 17 January 2014, 18:37:29 »
Only thing about Filco is that the legends on the keycaps might have faded a bit.  You might be looking at a replacement keycap set at some stage (but then you probably would be anyway).
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #13 on: Fri, 17 January 2014, 19:15:36 »
Shouldn't the proper comparison (tier) be between a ficlo mj2 and a ducky pro g2 or the new premier or the shine 3 if you want backlights?
Not sure why you're comparing a MJ2 to a ducky zero.
They're not in the same "tier".
« Reply #14 on: Fri, 17 January 2014, 19:26:07 »
+1
You'll be comparing the premier and the MJ2. Having not used the premier yet, I can't say it's better, but the MJ2 is my favorite keyboard and I dislike PBT.
Offline Battou62
« Reply #15 on: Fri, 17 January 2014, 22:34:35 »
This Ducky 2108 I am typing on is built like a tank. I can't imagine the Filco being that much better than the Ducky. I wasn't really impressed with the Ducky on paper until I played with one in person. It's a very solid and well built board.
« Last Edit: Fri, 17 January 2014, 23:03:36 by Battou62 »
« Reply #16 on: Fri, 17 January 2014, 23:14:32 »
filco
ducky sucky
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« Reply #17 on: Sat, 18 January 2014, 01:09:04 »
If you can get MJ2 and Zero at the same price
absolutely you must go with the FILCO :thumb:
Offline Emospence
« Reply #18 on: Mon, 20 January 2014, 23:46:33 »
Definitely Filco mang
Keyboards: Topre Realforce 87UW 55g x 2
Mice: Zowie EC1 eVo CL x 2
Mousepads: Artisan Hien VE x 2, Razer Mantis Speed
