Author Topic: [Help] WASD spacebar QFR compatability?  (Read 2434 times)
Offline oNinjaDispatcho
« on: Sat, 18 January 2014, 16:29:07 »
Is the standard 6.25" wasdkeyboards.com spacebar compatible with the QFR?
http://www.wasdkeyboards.com/index.php/spacebar-cherry-mx-keycap.html#ad-image-0
Thanks
QFR Mx Reds
Offline Lu_e
Re: [Help] WASD spacebar QFR compatability?
« Reply #1 on: Sat, 18 January 2014, 16:33:37 »
yes, as long as you dont have cherry profile caps or something.
It would still work, would just be a little taller IF you had cherry caps.
Just say NO to ABS keycaps
Offline nuclearsandwich
« Reply #2 on: Sat, 18 January 2014, 16:35:49 »
Thanks
Yep. I had WASD blanks on my QFR all summer.
« Reply #3 on: Sat, 18 January 2014, 17:24:47 »
Thanks
Sweeeeeet
QFR Mx Reds
