Author Topic: What about painting plastic keyboard cases ?  (Read 1945 times)
Offline kilogeek
  • Nostalgy of a time when quality was a value
« on: Sun, 19 January 2014, 03:33:07 »
I searched on this forum (and on the web) but did not found what I'm looking for :
When you get a vintage keyboard you have 2 options, if you are a collector I guess you only want to clean or retrobright it, but if you're not you may want to paint it. The thing is I found very few information (web) on best methods to get durable painted plastic that won't go away with time. I'm thinking of tinted epoxy/polyester resins as I used these for crafting custom windsurf boards and I know it's strong... you can also add a layer of epoxy-kevlar on your keyboard^^  But I want a keyboard, not a mace.
What I'm looking for is a not too complicated way to get what I want : change case color for ever.
If any of you have advices, methods, links, products, thanks to reply.
« Last Edit: Sun, 19 January 2014, 03:34:38 by kilogeek »
"Ne pas subir" - Devise de Saint-Cyr.
Offline modbot
  • Customizer
    • Modbot
Re: What about painting plastic keyboard cases ?
« Reply #1 on: Sun, 19 January 2014, 03:37:24 »
I think if you want to get a good guide with people that are well versed with this you should check the "making stuff together" thread. There are a lot of useful resources and people that have approached painting keyboards in different ways with quite a high success rate.
Offline modbot
  • Customizer
    • Modbot
« Reply #2 on: Sun, 19 January 2014, 03:39:36 »
we just posted a photo ourselves of a filco we did, colour change from black to white, we use premium grade car paint and clear coat so you can use this as a reference for how you want your keyboard to turn out.
Offline kilogeek
« Reply #3 on: Sun, 19 January 2014, 03:44:33 »
thanks a lot, I'll read these threads, that was not obvious in what the search engine found^^
« Reply #4 on: Sun, 19 January 2014, 04:03:49 »
This section also has lots of information about painting cases.
Offline kilogeek
« Reply #5 on: Sun, 19 January 2014, 04:10:53 »
Nice sub-forum !
Think I found what I was looking for : the crucial point in this type of painting is the clear layer quality. Google will help me find the best products in my area.
(army-green matte would look nice on my Bull keyboard^^)
