Author Topic: Using CAPS LOCK instead of SHIFT??  (Read 9027 times)
Offline overthetop
« on: Tue, 21 January 2014, 08:35:55 »
Hey guys,
I write a lot of code every day and the main problem that I'm facing is writing capital letters in the words that I'm typing.
Something like: var giveMeThatVar = this.ShowMeTheVarsThatINeedToKnow();
Is it really worth it to get used to CAPS LOCKS? I just want to speed up my coding as much as I can...
Did someone here tried that thing?
Offline ideus
  • Björkö.
Re: Using CAPS LOCK instead of SHIFT??
« Reply #1 on: Tue, 21 January 2014, 08:54:23 »
I use caps lock for control, and I found it very handy. Why you need an extra shift in top of the actual one?
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #2 on: Tue, 21 January 2014, 09:08:41 »
Hey guys,
Have you thought about getting a foot switch and mapping that to Shift?
Offline yasuo
  • spanengan puyeng newbie
« Reply #3 on: Tue, 21 January 2014, 09:12:53 »
Swap shift on Alt :D
or uses SpaceFNShift(pressed) ;D
« Last Edit: Tue, 21 January 2014, 09:14:52 by yasuo »
Logitech MK220 Colemak DH
Offline overthetop
« Reply #4 on: Tue, 21 January 2014, 09:26:45 »
I'm not sure that I understand what you have just said. How exactly do you write capital letters in the words if you don't use the SHIFT key combination?
Offline Linkbane
« Reply #5 on: Tue, 21 January 2014, 10:29:13 »
You know, something that I found helpful while typing was to use StickyKeys, so you can tap Shift without having to hold it down.
Also works for Ctrl/Alt/Windows.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline overthetop
« Reply #6 on: Tue, 21 January 2014, 10:38:20 »
Hi :),
I have tried StickyKeys and I don't like them for coding. But thanks for the suggestion.
« Last Edit: Tue, 21 January 2014, 14:26:29 by overthetop »
Offline Linkbane
« Reply #7 on: Tue, 21 January 2014, 10:45:09 »
Hi :),
Of course. Have you gotten a mechanical, by any chance?
« Last Edit: Tue, 21 January 2014, 15:19:42 by Linkbane »
Offline ideus
  • Björkö.
« Reply #8 on: Tue, 21 January 2014, 12:19:39 »
The use of caps for control does not alter the use of regular shift. The caps was swapped to left control.
Offline overthetop
« Reply #9 on: Tue, 21 January 2014, 14:28:12 »
Hi Albert :),
Yeah, QuickFire Tk is the name of the game :). But no custom caps for now :(.
« Reply #10 on: Tue, 21 January 2014, 15:03:18 »
I hardly ever use caps lock, coding or whatever.
It takes too long to move my hand over to press it, come back to press one alpha key, move my hand back to press caps lock again, then continue typing for another few characters.
Much, much quicker just to tap Shift for as long as it takes.
Offline ideus
  • Björkö.
« Reply #11 on: Tue, 21 January 2014, 16:32:17 »
I do that myself also. It works pretty well. Now I have two left control keys.
Offline Linkbane
« Reply #12 on: Tue, 21 January 2014, 17:13:22 »
Hi Albert :),
TK life! Also, if you want to try customs, I recommend trying out the Keycool PBT from banggood first. Incredibly cheap (~$17, free shipping from China, very slow) and medium-thick blank white.
Offline overthetop
« Reply #13 on: Thu, 23 January 2014, 03:28:19 »
Hi :),
Actually I will reconsider THIS! :)
Offline kolonelkadat
  • Location: the vicinity of an area adjacent to a location
    • Force Project X
« Reply #14 on: Thu, 23 January 2014, 04:35:08 »
caps lock doesnt give _ when you type -, so **** caps lock.
Im either going to replace capslock with a latching shift key, or add hold on-press off latching circuitry to right shift. atm it,s looking like the latter. I just need to tighten up the r/c values and it will be ready to install.
"Obviously, windows are central to Windows. But what is a window?"
Offline mrmillsy
« Reply #15 on: Thu, 23 January 2014, 06:23:03 »
I never use caps lock except by mistake.
Offline overthetop
« Reply #16 on: Thu, 23 January 2014, 08:54:57 »
Actually many fast typists are using CAPS LOCK for the capital letters. It's just difficult to get used to in my opinion.
Offline SonOfSonOfSpock
« Reply #17 on: Thu, 23 January 2014, 09:03:19 »
Back in school when I was learning to type I remember them saying to only use CAPS LOCK if you're going to be typing 3 or more capital letters in a row. Otherwise, it would be better to just use shift. If you're typing a single capital letter it seems a lot easier to hit shift with the opposite hand than to use CAPS LOCK.
Offline mrmillsy
« Reply #18 on: Thu, 23 January 2014, 09:21:12 »
That's really weird to me.  Do you think you could explain it?  I'll have a google in the meantime.
Similar to the OP, I do a lot of camelCasingOfLongIshVariableNames and so on, I'd be amazed to see CAPS as more suited to that task.
Though, to be fair, I mostly just use TAB to type them =D
Offline neunelfer
  • HHKB Pro
« Reply #19 on: Thu, 23 January 2014, 09:22:00 »
I've never heard of that.. pressing and holding shift briefly requires less time and coordination than toggling caps lock for single letters.
Offline mrmillsy
« Reply #20 on: Thu, 23 January 2014, 09:31:14 »
After a quick google, I found this post, which includes a reply from Sean Wrona himself:
http://forum.colemak.com/viewtopic.php?id=1309
With regard to caps lock vs. shift, I meant exactly what I said there.  When typing capital letters, I virtually always use caps lock, not shift (occasionally there are exceptions).  I infinitely prefer caps lock to shift for a variety of reasons.  I am considerably more accurate with caps lock because when you are holding down the shift key, there are a variety of other things you have to think about that makes typing a capital letter considerably more complicated.  Did I press the key hard enough for it to register?  Did I make sure to release it immediately before typing the next character?  This can be very hard at around 200 wpm (where the vast majority of typos I find are me hitting the space bar one character too early or one character too late).  You have to release the shift key at the exact right moment which at my speed can be very difficult since that would be within a tenth of a second or less, and not making an error there is by no means guaranteed (in fact, I frequently do whenever I have to use shift, i.e. characters such as !@#$%^...)  Furthermore, I don't like shift because it locks my left pinky into place and therefore forces my left hand to be locked into place.  Given my main typing strategy which I detailed above, I like to NOT have a fixed location for either my left or right hand and slightly vary it according to the context of the words.  My left hand is not usually fixed near the shift key when I am typing, so holding down the shift key and locking my left hand into a place I would not normally put it would mess me up.  For these main reasons, I am much more comfortable using caps lock than shift for any capital letters, but obviously I do use shift for the characters I need to.  However, if you're a traditional home-row typist who for the most part does not vary the finger you use based on the other letters in the word, Shift is probably preferable.
It looks like it can help to regulate your typing if you're at 200wpm by ensuring sequential capsing and avoiding accidental shifting.  It can also free up your left hand to move over to the right [for one keypress ...] if you're doing some weird voodoo passage which requires all 10 fingers to hover around the symbols block.
I'm at 110wpm and the problem of mistiming the shift presses hasn't reared it's head at me yet.  My fingers do roam a bit, but not much, mostly they're pretty static, so I think I'm safe with never ever ever using the CAPS key =D
I've actually just re-mapped it to backspace as an experiment.  We'll see how it goes after I get my work to a point where I can restart.
Offline Linkbane
« Reply #21 on: Thu, 23 January 2014, 10:33:43 »
I'm at about 140 wpm, and the shift error has started to pop up often enough; that's why using StickyKeys has turned out to be very useful for me. Perhaps the reason that the error isn't popping up (as your speed isn't really that far off from mine, is that you consciously slow down to use Shift. If you're typing out a word full speed, it's very difficult for someone with non-inhuman coordination to not mess up the Shift usage.
« Last Edit: Thu, 23 January 2014, 11:10:54 by Linkbane »
« Reply #22 on: Thu, 23 January 2014, 10:36:25 »
What is 'non-inhuman coordination'??
Offline Linkbane
« Reply #23 on: Thu, 23 January 2014, 11:11:15 »
What it sounds like, normal coordination.  :p
Offline user888
« Reply #24 on: Thu, 23 January 2014, 11:26:30 »
I never used caps lock. So I started it to map it as CTRL, but only benefited from it in a terminal or SSH session: I'm using a Mac, which has all important shortcuts mapped to the Command key. So I thought about mapping it to the Command key, but I use my thumb for pressing that key and that doesn't cause any strain (as opposed to using my pinky for CTRL).
So, after test-driving Colemak for quite some while I have it now mapped to backspace, which is wonderful. You don't have to lift your hand anymore from the keyboard when making a mistake.
Offline neunelfer
  • HHKB Pro
« Reply #25 on: Thu, 23 January 2014, 11:31:32 »
I map CMD to Caps on my Macbook.
Offline Grim Fandango
« Reply #26 on: Thu, 23 January 2014, 18:41:38 »
I have always just left it as Capslock, which is kind of a waste, because it takes up some premium keyboard real estate and it is practically never used. In fact, it is more often in the way and pressed accidentally than I actually use it.
May remap it to something else, anything else.
« Reply #27 on: Thu, 23 January 2014, 18:48:37 »
I don't really map anything - I prefer to keep my keyboards standard layout.
The only difference I have is swapping to HHKB - but that is sufficiently different to everything else I have that I can load a different mental template when I type on it.
Offline TrueOP
« Reply #28 on: Thu, 23 January 2014, 21:08:15 »
Not a programmer, but it seems what you just wrote has only 2 Capitals in a row there...  Not sure if just a bad example or what but it seems pointless to Capslock those 2 letters.
I never understood the prominent spot of Caps lock on keyboard.  The only use i have seen would be engineering (military also?) docs that use all caps in certain areas of the text like specifications/warnings/etc.  Also traffic signs in :o
*AND really angry gamers hehe
« Last Edit: Thu, 23 January 2014, 21:09:51 by TrueOP »
Noppoo Choc Mini
Offline ideus
  • Björkö.
« Reply #29 on: Thu, 23 January 2014, 21:33:08 »
I began using the Caps Lock as Control key just a week ago, and now I just can't swap it back to caps lock. For the first time ever my ctrol+ commands are so fluent. I left the left control as is, and the right one is normally an arrow key in my Poker.
« Reply #30 on: Fri, 24 January 2014, 03:03:05 »
You are on the path to appreciating the HHKB layout :)
Offline ideus
  • Björkö.
« Reply #31 on: Fri, 24 January 2014, 08:00:37 »
I hope not. I do not want to be spending all that money in a keyboard by any means. Besides, I like way too much to change sets, and topres are not the best switches for "keyboard-dressing-up".
Offline davkol
  •  Post Editing Timeout
« Reply #32 on: Fri, 24 January 2014, 09:29:59 »
GH60
