Author Topic: Need suggestions  (Read 1272 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Need suggestions
« on: Tue, 21 January 2014, 11:44:26 »
Hey guys I need a bit of help.  I want to dye a set of caps for the wifes keyboard but neither one of us like the way that dye subbed legends come out after the heat and dye process.  So, I am on the look for some lasered PBT caps for a dye job.  What I am looking for is a cheap-ish keyboard that I can source from here or some other auction site with lasered PBT caps.  Ivan pointed me toward a G81-8000 MY board, the only problem is the caps are going on a filco and the stepped caps lock won't work.
So, any suggestions on a board that would have lasered PBT but a standard capslock with US ANSI layout?  Doesn't need a ten key pad since the Filco is TKL.
Melvang
