Author Topic: SGI Granite with White Alps?  (Read 2314 times)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« on: Tue, 21 January 2014, 14:09:00 »
was not aware they came in white...........only thought they came in cream- go figure
reputable seller
http://www.ebay.com/itm/VINTAGE-GRAY-GRANITE-SGI-PS-2-KEYBOARD-WHITE-ALPS-SLIDERS-/261380088134?hash=item3cdb77a146
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline JimByr
  • ...old guy...
Re: SGI Granite with White Alps?
« Reply #1 on: Tue, 21 January 2014, 15:41:52 »
The switches are the same as the damped cream... just white sliders instead of cream. I have one.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #2 on: Tue, 21 January 2014, 16:41:44 »
so they r dampened and feel like creams?
Offline JimByr
  • ...old guy...
« Reply #3 on: Tue, 21 January 2014, 16:59:30 »
Yes. They are the same dampened switch AFAIK. The only difference is the color of the slider. They are not clicky, tactile white Alps. The SIG Granite keyboard that I have has dampened Alps irrespective of the slider color. (Disclaimer... I haven't done a disassembly side-by-side comparison of the switches with cream and white sliders. And don't have a board with the cream variant.)
My SGI board is light years different from an Omnikey with complex white Alps and a Focus with simplified white Alps. Between the three, the Omnikey wins hands down.  ^-^
« Last Edit: Tue, 21 January 2014, 17:16:06 by JimByr »
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #4 on: Tue, 21 January 2014, 17:00:18 »
from DT Wiki
Alps SKCM Cream Damped, or cream Alps ("ivory" according to the Alps 1994 catalogue), is a tactile clicky switch in the Alps SKCL/SKCM series.
Damped cream Alps switches have small black rubber dampers on either side of the slider. The damper does not reach to the bottom of the slider, so the stops moulded into the base of the shell protrude a little higher to accommodate.
Damped switches with white sliders also exist, and it's not clear whether or not this is the same switch. Cream sliders have also been found used without rubber dampers, giving a normal undamped tactile switch.
so then you r sure they r acting dampened?
Offline JimByr
  • ...old guy...
« Reply #5 on: Tue, 21 January 2014, 17:17:14 »
Absolutely no question that they are dampened. (See above.) I've had Alps keyboards since the 80s and just was given a OEM Acer 6011 that came from Wang. It has complex white Alps but feels more like the Focus above.
« Last Edit: Tue, 21 January 2014, 17:20:25 by JimByr »
Offline AKIMbO
  • HHKBro
« Reply #6 on: Tue, 21 January 2014, 18:07:50 »
The dampened white alps and dampened cream alps in SGI keyboards feel exactly the same.  I've had both variants in SGI keyboards.  IIRC the dampened white alps version is rarer.
| KBD75 (box reds)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #7 on: Tue, 21 January 2014, 18:37:16 »
learn something new everyday-- thanks guys
