Author Topic: Mini USB switcher  (Read 2270 times)
Offline eosph
Mini USB switcher
« on: Tue, 21 January 2014, 15:57:29 »
Does such a thing exist? I want to use the same keyboard and switch between my pc and macbook air at my desk but don't want to have to keep putting strain on my ducky 3 usb port.
Re: Mini USB switcher
« Reply #1 on: Tue, 21 January 2014, 15:59:59 »
Just get one of the custom cable makers to make you a short pigtail and then you can just detach at that connection.
Or just get any short cable with the proper connection for your keyboard on one end and female on the other.
« Last Edit: Tue, 21 January 2014, 16:02:57 by SpAmRaY »
« Reply #3 on: Tue, 21 January 2014, 16:13:33 »
Oh I think I misunderstood the request, what rowdy posted or maybe something like this?
http://www.ebay.com/itm/ZH2A-Sharing-Switch-2-Port-for-PC-Printer-Sharing-Device-Mini-USB-1-1-2-0-/111221247586
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
« Reply #4 on: Tue, 21 January 2014, 16:15:45 »
I could make a short Mini male to female cable, save your port on the board
« Reply #5 on: Tue, 21 January 2014, 16:20:15 »
Or ... why not get a second keyboard? ;D
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #6 on: Tue, 21 January 2014, 16:42:50 »
Perhaps a KVM? I don't need to do anything particularly intensive on one of my machines so I simply RDP into it. You could also try synergy.
« Reply #7 on: Tue, 21 January 2014, 17:05:14 »
Many modern KVMs include USB ports, but tend to be a fair bit more expensive than just a USB switcher.
« Reply #8 on: Wed, 22 January 2014, 13:28:55 »
It really depends... there are lot of cheap ones that only have 2x usb and dsub vga for around like $10-15. Those that have a DVI/DP/HDMI + audio and etc are expensive. But in the OP case where they are just use for input device and not display I guess it wouldn't make a difference and cheap one would do just fine.
Offline neun_sechs_zwei
« Reply #9 on: Wed, 22 January 2014, 14:13:43 »
How about Synergy or something similar? http://synergy-foss.org
Been years since I needed something like this so I haven't tried Synergy myself. But I used to have my keyboard/mouse setup on a Linux box, then would control a laptop with x2vnc (running a vnc server on the laptop).
There was also always a keyboard hotkey for switching inbetween, and copy/paste worked, too, so you could that between machines very quickly.
