Author Topic: shortest spacebar you can buy/order/make  (Read 4278 times)
Offline litster
  • rare caps?! THAT'S A SMILIN
« on: Tue, 21 January 2014, 23:07:20 »
Looking at SP's spec sheet, the shortest spacebar they make is 4.5x.  Are there any other sources that can do spacebars in 3x, 3.5x, or 4x?  Thanks.
Re: shortest spacebar you can buy/order/make
« Reply #1 on: Tue, 21 January 2014, 23:10:43 »
what profile?? 7bit's went crazy with spacebars in R5 but they are SA profile.
Offline litster
« Reply #2 on: Tue, 21 January 2014, 23:22:55 »
pretty much any profile.  As it is hard to find the right length, length is more important than profile.  What lengths are available in SA profile?
Offline Pacifist
  • on hiatus
« Reply #3 on: Tue, 21 January 2014, 23:24:01 »
i remember people got 3x spacebars for their minilas
« Reply #4 on: Tue, 21 January 2014, 23:26:26 »
he has mockups for both 3 and 4 unit spacebars
http://deskthority.net/wiki/Round_5
Offline litster
« Reply #5 on: Tue, 21 January 2014, 23:40:03 »
Pacifist, any link to the 3x spacebars for the mini?  I can't find it :-(  Thanks.
Offline Pacifist
  • on hiatus
« Reply #6 on: Tue, 21 January 2014, 23:49:54 »
I don't remember. The original thread is closed. its one of the flat profiles by SP and u can get it in their warehouse
Offline tbc
« Reply #7 on: Tue, 21 January 2014, 23:56:42 »
if you're talking about the one from unicomp_lover or something rather,
it wasn't a 'spacebar', it was a 3x key (or w/e the proper length is).  the significance being that the spacebar was concave like any other key and NOT convex like a spacebar is supposed to be.
Offline yasuo
  • spanengan puyeng newbie
Logitech MK220 Colemak DH
Offline litster
« Reply #9 on: Wed, 22 January 2014, 00:12:21 »
http://geekhack.org/index.php?topic=46620.30
Ooh, that is gonna hurt the thumb...
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #10 on: Wed, 22 January 2014, 13:21:49 »
Are you making something custom? Why not use a 2.75 since it is super easy to get a blank right shift. I have that size as space on Japanese Cherry G80 keyboard which is same as right shift in shape and I don't think it's bad at all.
Offline litster
« Reply #11 on: Wed, 22 January 2014, 13:53:57 »
Hi Ivan!  Yes, something custom.  I thought about the 2.75x right shift.  It is just that the sharp edge on the shift key would hurt the thumbs because it is not convex.  Ivan, do you know if GMK makes shorter spacebars?
« Reply #12 on: Wed, 22 January 2014, 13:56:27 »
I was told the shortest spacebar profile they have is 6x. If you use Cherry key, it's really not bad at all using the right shift as space since Cherry B row isn't too sharp... and you could always put it on upside down.
« Last Edit: Wed, 22 January 2014, 13:58:22 by IvanIvanovich »
Offline litster
« Reply #13 on: Wed, 22 January 2014, 14:02:50 »
That's true, upside down is not as sharp.  Now, I need to find blank 2.75x shift keys :-)
« Reply #14 on: Wed, 22 January 2014, 14:08:30 »
What color?? I think I've got some...
