Author Topic: Seems Pretty Neat...  (Read 2688 times)
Offline 127001
« on: Wed, 22 January 2014, 23:08:37 »
Re: Seems Pretty Neat...
« Reply #1 on: Thu, 23 January 2014, 00:18:06 »
Neat indeed! It popped up on my eBay searching earlier. I was going to bid on it, but now that it's posted here, I don't think I'll bother. More fun to sit back, (save money,) and watch the excitement!
Some tings to remember: Keytronic made magnetic reed switch keyboards before they started on the (almost universally hated) foam&foil capacitive design.
Now, it does look different than this reed switch keytronic but who knows?
« Last Edit: Thu, 23 January 2014, 01:24:46 by dorkvader »
Offline E TwentyNine
    • Some of My Keyboards
« Reply #2 on: Thu, 23 January 2014, 08:36:34 »
Would be neater if you made threads with a descriptive title.
Makes it a lot easier to find a thread later on.
Offline 127001
« Reply #3 on: Thu, 23 January 2014, 08:48:04 »
*baby voice * Who's a grumpy guss?! Who's a grumpy guss?! You are!
Offline mr_a500
« Reply #4 on: Thu, 23 January 2014, 09:01:58 »
Yes, that's neat. It looks much nicer in that case than in the usual Sol 20 case:
According to this page, it does appear to be foam and foil.
« Last Edit: Thu, 23 January 2014, 09:05:06 by mr_a500 »
« Reply #5 on: Thu, 23 January 2014, 09:10:24 »
So what is it?
« Reply #6 on: Thu, 23 January 2014, 14:49:21 »
So what is it?
I had another look at the PCB and it's not reed.
I had a look at google patents and the first patent assigned to "key Tronic Corporation" was in 1980 (filed in 1978) (for a capacitive keyswitch). Since there are several records of kbs from 1977 from them, I wonder what switch they used.
« Reply #7 on: Thu, 23 January 2014, 14:50:32 »
So what is it?
Someone's just going to have to buy it and find out haha :P
Offline mr_a500
« Reply #8 on: Thu, 23 January 2014, 15:08:12 »
So what is it?
Or you could just read my post. I already said it's most likely foam and foil.
« Reply #9 on: Thu, 23 January 2014, 15:13:02 »
So what is it?
missed your edit! thanks for pointing it out.
Offline JimByr
  • ...old guy...
« Reply #10 on: Thu, 23 January 2014, 15:29:34 »
Interesting... I had a Sol 20 like pictured above. That was my second microcomputer. Have never seen a stand-alone keyboard.
« Last Edit: Thu, 23 January 2014, 15:31:52 by JimByr »
