Author Topic: Steelseries sensei common issues  (Read 2497 times)
Offline Ghetto Caps
  • i make ghetto caps.
« on: Thu, 23 January 2014, 21:33:04 »
Hmm so ive been using my sensei for like 7 months playing star-craft/crossfire for a good 2 hours a day, recently it keeps getting disconnected and i wait like 10 minutes then it starts working.
Has anyone else experienced this issue?
Visit the Typing Test and try![/sigpic]
Offline vun
  • Just one more thing
Re: Steelseries sensei common issues
« Reply #1 on: Thu, 23 January 2014, 21:38:18 »
Not sure if this is a Sensei-specific issue, but as with all mice that randomly disconnect I would suggest opening it to check if the USB cable is properly attached inside. Of course, that will probably void warranty and stuff, so if you want to RMA it you should probably just do that right away instead of poking inside it.
Offline Ghetto Caps
« Reply #2 on: Thu, 23 January 2014, 21:42:07 »
i never keep receipts or register any type of warranty :)
open up  the mouse,
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #3 on: Thu, 23 January 2014, 21:42:20 »
mine will sometimes disconnect on my windows 7 machine after it goes to sleep, but never disconnected that i can recall on my win 8 'puter
weird........
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline vun
« Reply #4 on: Thu, 23 January 2014, 22:38:09 »
weird........
Power save settings maybe?
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #5 on: Thu, 23 January 2014, 22:47:11 »
yea.........i was thinking maybe it was that but have just been shutting it down lately where i do not have that prob
Offline oscillik
    • music podcasts
« Reply #6 on: Fri, 24 January 2014, 06:36:11 »
I haven't had this issue with mine, but I have another issue whereby whenever I do a firmware update, every single goddamned time, it will fail part way through and requires me to disconnect/reconnect the mouse and start again.
When it happened the first time, I just thought it was a fluke. but then it did it the second time there was new firmware. and the third. and the fourth.
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
