Author Topic: Where to buy 2X R Shift  (Read 2864 times)
Offline Pacifist
  • on hiatus
« on: Fri, 24 January 2014, 20:07:11 »
I have a 2X right shift on my 11900, is there any place to get 2x r shifts? Preferably green and doubleshot in cherry profile, or sp profiles.
Offline phoenix1234
Re: Where to buy 2X R Shift
« Reply #1 on: Fri, 24 January 2014, 20:15:58 »
I had same quest as you because I have two G80-11800 and one G80-11900 so I tried to look a round. Eventually, the only place that I can find so far is this place :
http://www.wasdkeyboards.com/index.php/products/blank-keycap-singles/row-4-size-1x2-00-cherry-mx-keycap.html
It is not quite a shift (R3) but it works at least.
I like linear switches
Offline ebacho
« Reply #2 on: Fri, 24 January 2014, 20:18:43 »
Yeah, 2x isn't a particularly common size.  Short of buying a different 11800/11900 with caps of choice (POM/Lasered PBT/Doubleshot ABS) not sure where you can get them either.
Offline Pacifist
  • on hiatus
« Reply #3 on: Fri, 24 January 2014, 20:21:42 »
I'd rather not buy a different profile.
How would the uniform caps work? If I go for uniform, does sp have off center 6x spacebars?
« Reply #4 on: Sat, 25 January 2014, 19:37:10 »
Not as far as I know, but I know that they have 2x right shifts.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Sat, 25 January 2014, 19:50:46 »
I know it's not exactly what you may be after... but maybe place a WTB for blank numpad zero keys from imsto sets? Some people that are not fullsize user may be willing to part with numpad keys and at least it's same Cherry profile.
