Author Topic: DIY Keyboard Magnets  (Read 3428 times)
Offline BobbyTables
« on: Sat, 25 January 2014, 16:12:25 »
I thought this was a neat idea to recycle old keycaps :)
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
Re: DIY Keyboard Magnets
« Reply #1 on: Sat, 25 January 2014, 16:22:28 »
Or you know. Something like this
I 3D printed this one, but the success of these printing were like 1/10 so I didn't do any more and I contacted SP where they told me.... $3800 to get a custom mold, GB guys?
Offline kmiller8
« Reply #2 on: Sat, 25 January 2014, 16:47:43 »
And here's a guide for anyone to make their own with some spare MX stems :D
Things you need:
Dremel (or something for cutting)
Epoxy (I used superglue, epoxy would be better)
5mm x 1.5mm magnets (I used 3x1mm, they can hold up a keycap, but just barely)
MX Stems
Start with a MX stem
Shave off the "legs"
Flatten the area for the magnet to stick
Like I said, if I'd do it again, 5mm magnets and epoxy
Stuck pretty easily
Fits perfectly
Yey!
« Last Edit: Wed, 29 January 2014, 15:21:34 by kmiller8 »
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Sat, 25 January 2014, 18:13:03 »
You could do a lot less work if you have some MY keyboards... Just break the tabs that hold MY switch onto the plate off, and epoxy magnet. Done. It's not as if those keyboards are any good for typing or something... it's good to find alternate uses.
Offline kmiller8
« Reply #4 on: Sat, 25 January 2014, 18:13:41 »
yeah, but who has MY keyboards just... lying around
« Reply #5 on: Sat, 25 January 2014, 18:14:47 »
I inevitable end up with them quite often... since they come along unwanted with cheap Cherry doubleshot sets.
Offline kmiller8
« Reply #6 on: Sat, 25 January 2014, 18:16:29 »
Ship me a few ;)
srs tho, I'd have no problem making a bunch of these to just giveaway or something.
« Reply #7 on: Sat, 25 January 2014, 19:46:41 »
I can send you a whole MY 1800 assembly. You can do the work to break them off.
Offline kmiller8
« Reply #8 on: Wed, 29 January 2014, 15:16:41 »
Made a few more with supplies on hand. This is why I plan on using bigger magnets :P
