Author Topic: Thickest ABS keycap?  (Read 6685 times)
Offline Pac Caps
  • Its almost a pallindrome
« on: Sat, 25 January 2014, 20:03:12 »
What's the thickest ABS keycap that you know of? I need some to make some caps. Is GMK the thickest or are there others?
Want to be a cap maker
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
Re: Thickest ABS keycap?
« Reply #1 on: Sat, 25 January 2014, 20:04:08 »
I think SA profile from SP is pretty thick, not sure how it compares to GMK/Cherry
Offline ideus
  • Björkö.
« Reply #2 on: Sat, 25 January 2014, 20:05:43 »
I have examples of both here and GMK is a little thicker. I hope that helps. It is also important to consider that they are really different profiles.
Offline Pac Caps
« Reply #3 on: Sat, 25 January 2014, 20:09:22 »
For novelty caps, are they usually in a profile similar to Cherry or SP or do most cap makers have their own profile?
Offline kmiller8
« Reply #4 on: Sat, 25 January 2014, 20:10:56 »
god dammit I just realized this was a pacifist thread, forgot to ignore your new account.
Offline ideus
  • Björkö.
« Reply #5 on: Sat, 25 January 2014, 20:13:01 »
Pac Caps = Pacifist?
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #6 on: Sat, 25 January 2014, 20:43:35 »
That's what I'm wondering.
Offline ideus
  • Björkö.
« Reply #7 on: Sat, 25 January 2014, 20:48:19 »
So this may be another kid's affair.
Offline phoenix1234
« Reply #8 on: Sat, 25 January 2014, 21:15:00 »
As kmiller8 mentioned, SP SA is the thickness ABS (as far as I know).
Perhaps because it has dual-layer.
52324-0
*below GMK is imsto thick PBT
I like linear switches
« Reply #9 on: Sat, 25 January 2014, 21:26:07 »
inb4cancel!
Offline bazh
« Reply #10 on: Sat, 25 January 2014, 21:34:43 »
The keycaps from Honeywell Hall Effect keyboard
(Photo from Murium @Desthority)
HHKB Pro2 white
Newbie again
« Reply #11 on: Sat, 25 January 2014, 21:47:35 »
Whoa, awesome comparison! I love my GMK..
« Reply #12 on: Sun, 26 January 2014, 07:50:19 »
On a Cherry MX switch, you can not get much thicker than GMK or original Cherry Corp/GMBH. keys or the keycap will not fit on the switch.
Many older keyboards with very thick keycaps also have longer stems, so that the keycap does not go over the switch housing the fully depressed like with Cherry MX.
Offline ideus
  • Björkö.
« Reply #13 on: Sun, 26 January 2014, 09:11:59 »
If you see the original post, it does not mention cherry stems.
« Reply #14 on: Sun, 26 January 2014, 09:22:57 »
He mentions GMK so its safe to assume he means cherry MX caps.
« Reply #15 on: Sun, 26 January 2014, 15:58:47 »
Actually although he mentions GKS, he does not say why he wants to know.  Whether the intention is to purchase a set of these keycaps for use on a particular keyboard, to buy a set to melt down (getting maximum plastic for money), to use as a basis for some keyboard science, or other (please specify).
