Author Topic: Side Pic of Cherry Profile?  (Read 2780 times)
Offline Pac Caps
  • Its almost a pallindrome
« on: Sun, 26 January 2014, 13:35:26 »
SP has side pictures of all their profiles, such as:
for DCS.
Is there a similar picture for Cherry profile? A sketch like the one for SP or a real picture of cherry caps from the side would suffice.
Want to be a cap maker
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Side Pic of Cherry Profile?
« Reply #1 on: Sun, 26 January 2014, 13:40:45 »
Though modern Cherry sets have double B and double E and don't use A or F.
« Last Edit: Sun, 26 January 2014, 13:43:21 by IvanIvanovich »
Offline epzy
  • HHKB Fiend
  • ded
« Reply #2 on: Sun, 26 January 2014, 13:42:47 »
Offline Pac Caps
« Reply #3 on: Sun, 26 January 2014, 14:02:21 »
Thanks for the pictures ;D
Offline moonexe
« Reply #4 on: Sun, 26 January 2014, 17:38:24 »
Are the 3800 overall the same height as regular cherry, or lower? Has anyone here tried typing on them? They look interesting.
G80-3000, MX brown           -           Filco Majestouch 2 HAKUA TKL+TK, MX brown, JIS Layout
« Reply #5 on: Sun, 26 January 2014, 18:13:23 »
The 3800 series is almost half the height of traditional Cherry profile.
Offline tbc
« Reply #6 on: Sun, 26 January 2014, 18:17:41 »
is there a comparison between them and dsa profile?
« Reply #7 on: Sun, 26 January 2014, 19:45:10 »
I have no picture, but
- the G80-3800's keycaps are cylindrical, somewhat leaning with a larger front than back. Almost precisely like an older laptop keyboard. As low profile as you can get on Cherry.
- the DSA profile is spherical and completely symmetric. You can rotate a blank DSA key 90° and it will look the same as before. It is medium-profile.
DSA profile is not low-profile. SP calls it "medium-profile". The keys are as high as the lowest profile-row on OEM profile.
