Author Topic: (solved) help me build the perfect board  (Read 1342 times)
Offline trentva
  • Trade Count: (0)
« on: Sun, 26 January 2014, 14:14:02 »
hello all. I'm trying to build the perfect mechanical keyboard to suite my needs. i would like to achieve something of a similar profile as seen with the poker 2 boards in the low profile 60% tex case, pretty much as slim as i can get without totally removing the case... i would want the board to have mx red switches lubed and stickered as smooth as possible other then topre.... and some printed dsa caps..if possible even a spring mod to resemble more of a 30g uniform weight then the standard 45g red switch weight...the thread below has pictures of what I'm going after. http://geekhack.org/index.php?topic=47376.0 thanks, i tried to find a topre short throw board as i thought it would be perfect and even contemplated a ml switch board lubed..I guess i'm kind of stuck at this point..any input would be greatly appreciated..im willing to pay for custom work thanks again
« Last Edit: Tue, 28 January 2014, 09:42:57 by trentva »
Offline Pacifist
  • Trade Count: (0)
  • on hiatus
Re: (WTB) help me build the perfect board
« Reply #1 on: Sun, 26 January 2014, 14:18:53 »
is 30g springs heavy enough to keep reds from activating themselves?
Offline trentva
  • Trade Count: (0)
Re: (solved) help me build the perfect board
« Reply #2 on: Sun, 26 January 2014, 14:23:58 »
i believe so...
« Last Edit: Tue, 28 January 2014, 09:42:20 by trentva »
  • Trade Count: (0)
« Reply #3 on: Sun, 26 January 2014, 14:25:04 »
Sounds like you want to build a GH60 in a Tex case with some modded switches.
